Aller au contenu principal
FAO Schwarz Apex 1 Front Wheel Springs Replacement
Ce dont vous avez besoin
  1. FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: étape 1, image 1 de 3 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: étape 1, image 2 de 3 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: étape 1, image 3 de 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Wheel Springs Replacement: étape 2, image 1 de 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Wheel Springs Replacement, Front Wheel Springs: étape 3, image 1 de 2 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Front Wheel Springs: étape 3, image 2 de 2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Wheel Springs Replacement: étape 4, image 1 de 1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Wheel Springs Replacement: étape 5, image 1 de 1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
April Wilson
Membre depuis le 09/07/18
374 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 182
