Introduction
Note: This guide is for the FLSUN QQ not the newer QQ-S
If you own a FLSUN QQ and the original bed is worn out, or if you simply want to upgrade for easier print removal, this guide will walk you through the process.
Recommended: If you have not upgraded to the leveling switch I recommend the FLSUN QQ Leveling Sensor Replacement guide first so that you can more easily level after installing the new print surface.
Ce dont vous avez besoin
Power up printer
Tap Tools
Tap Heat
Tap Extrude 1 to switch to Bed
Tap + till the bed temp is set to 70º
Use the putty knife to start peeling up the old bed.
Once you get the edge started you should be able to peel the rest by hand.
One side of the bed will have a wire taped in with the conductive sticker.
If you have upgraded to the leveling switch you can cut this wire.
If not, you could carefully peel the wire off of the conductive sticker to save it for later...
aluminum foil stuck to top of bed and connected to leveling wire
homemade leveling switch
etc.
Use mineral spirits, gloves, and cotton balls to clean the bed
Leave the steel plate and magnetic sticker together.
Remove the backing from the magnetic sticker.
Carefully apply the sticker and plate from one edge to the other.
Attach Leveling Switch
Heat Bed to Normal Printing Temperature
Tap Tools
Tap Leveling
Tap Level
Peel spring steel plate off of magnetic sticker.
Flex plate gently to detach print.
Retrieve print (I dropped the first one)
You have successfully upgrade the print surface of your FLSUN-QQ
Print Happy
Print Happy
