Aller au contenu principal
Fahrenheit FHT 125PRMR Power Cord Replacement
Ce dont vous avez besoin
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: étape 1, image 1 de 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: étape 2, image 1 de 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: étape 3, image 1 de 2 Fahrenheit FHT 125PRMR Power Cord Replacement: étape 3, image 2 de 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: étape 4, image 1 de 2 Fahrenheit FHT 125PRMR Power Cord Replacement: étape 4, image 2 de 2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: étape 5, image 1 de 1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
4 autres ont terminé cette réparation.
Joshua Potts
Membre depuis le 09/29/16
265 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-2, Harley Fall 2016 Membre de l'équipe IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 membres
4 tutoriels rédigés
3 commentaires
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Réponse
Where do you buy the power cord?
Dominique - Réponse
probably available at electronic store
john john - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 11
Total : 2,457
