Aller au contenu principal
Fairphone 1 Motherboard Replacement
Ce dont vous avez besoin
  1. Fairphone 1 Motherboard Replacement, Back Cover: étape 1, image 1 de 3 Fairphone 1 Motherboard Replacement, Back Cover: étape 1, image 2 de 3 Fairphone 1 Motherboard Replacement, Back Cover: étape 1, image 3 de 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Motherboard Replacement: étape 2, image 1 de 3 Fairphone 1 Motherboard Replacement: étape 2, image 2 de 3 Fairphone 1 Motherboard Replacement: étape 2, image 3 de 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Motherboard Replacement, Battery: étape 3, image 1 de 3 Fairphone 1 Motherboard Replacement, Battery: étape 3, image 2 de 3 Fairphone 1 Motherboard Replacement, Battery: étape 3, image 3 de 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: étape 5, image 1 de 3 Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: étape 5, image 2 de 3 Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: étape 5, image 3 de 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Motherboard Replacement: étape 6, image 1 de 2 Fairphone 1 Motherboard Replacement: étape 6, image 2 de 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Motherboard Replacement, Midframe Assembly: étape 7, image 1 de 1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Motherboard Replacement: étape 8, image 1 de 3 Fairphone 1 Motherboard Replacement: étape 8, image 2 de 3 Fairphone 1 Motherboard Replacement: étape 8, image 3 de 3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Motherboard Replacement: étape 9, image 1 de 2 Fairphone 1 Motherboard Replacement: étape 9, image 2 de 2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Motherboard Replacement: étape 10, image 1 de 1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Motherboard Replacement: étape 11, image 1 de 3 Fairphone 1 Motherboard Replacement: étape 11, image 2 de 3 Fairphone 1 Motherboard Replacement: étape 11, image 3 de 3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Motherboard Replacement: étape 12, image 1 de 1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Motherboard Replacement, Motherboard Assembly: étape 13, image 1 de 3 Fairphone 1 Motherboard Replacement, Motherboard Assembly: étape 13, image 2 de 3 Fairphone 1 Motherboard Replacement, Motherboard Assembly: étape 13, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  14. Fairphone 1 Motherboard Replacement: étape 14, image 1 de 1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  15. Fairphone 1 Motherboard Replacement: étape 15, image 1 de 2 Fairphone 1 Motherboard Replacement: étape 15, image 2 de 2
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  16. Fairphone 1 Motherboard Replacement: étape 16, image 1 de 3 Fairphone 1 Motherboard Replacement: étape 16, image 2 de 3 Fairphone 1 Motherboard Replacement: étape 16, image 3 de 3
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  17. Fairphone 1 Motherboard Replacement: étape 17, image 1 de 1
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  18. Fairphone 1 Motherboard Replacement: étape 18, image 1 de 2 Fairphone 1 Motherboard Replacement: étape 18, image 2 de 2
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  19. Fairphone 1 Motherboard Replacement: étape 19, image 1 de 2 Fairphone 1 Motherboard Replacement: étape 19, image 2 de 2
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  20. Fairphone 1 Motherboard Replacement: étape 20, image 1 de 1
    • Remove the motherboard from the display assembly.
  21. Fairphone 1 Motherboard Replacement, Rear Camera: étape 21, image 1 de 3 Fairphone 1 Motherboard Replacement, Rear Camera: étape 21, image 2 de 3 Fairphone 1 Motherboard Replacement, Rear Camera: étape 21, image 3 de 3
    • Use the flat end of a spudger to disconnect the rear-facing camera cable connector from its socket on the motherboard.
    • Remove the rear facing camera from the motherboard.
  22. Fairphone 1 Motherboard Replacement, Motherboard: étape 22, image 1 de 1
    • Motherboard remains.
    • Remember to remove all the plastic seals of the new motherboard. You will find at least one covering the microphone for dust protection.
8 autres ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
504 362 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 086 tutoriels rédigés
Un commentaire
This is a wonderful and detailed guide - thank you. However, I followed the instructions precisely and whilst the phone now switches on perfectly, the touchscreen does not work. Thoughts on how ifixthat welcome!!
Anthe George - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 17
Total : 9,366
