Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will show the user how to replace the retention pin on a 2016 Toyota Tacoma for a Tonneau Trifold Bed cover.
Outils
Pièces
Aucune pièce spécifiée.
  1. Use the Allen wrench and apply constant pressure counterclockwise to loosen the pins The pins are tight and may require some force. The pins are tight and may require some force.
    • Use the Allen wrench and apply constant pressure counterclockwise to loosen the pins
    • The pins are tight and may require some force.
  2. Repeat step one until both pins have been loosened. The pin should be loose enough to remove by hand. Repeat step one until both pins have been loosened. The pin should be loose enough to remove by hand.
    • Repeat step one until both pins have been loosened. The pin should be loose enough to remove by hand.
  3. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  4. Once loosened, grab both pins and pull them out. Line up the holes on the replacement part, then insert the pins. Line up the holes on the replacement part, then insert the pins.
    • Once loosened, grab both pins and pull them out.
    • Line up the holes on the replacement part, then insert the pins.
  5. Hand tighten the bolts. Hand tighten the bolts. Hand tighten the bolts.
    • Hand tighten the bolts.
  6. Tighten down one side then proceed to the next step. Do not over tighten because you can strip the screw.
    • Tighten down one side then proceed to the next step.
    • Do not over tighten because you can strip the screw.
  7. Tighten down the final side. Do not over tighten because you can brake the allan wrench  and strip the screw.
    • Tighten down the final side.
    • Do not over tighten because you can brake the allan wrench and strip the screw.
To reassemble your device, follow these instructions in order.
Christopher King
Membre depuis le 16/01/2018
139 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 membres
16 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 81
