Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Fast Fix Screen Replacement
Ce dont vous avez besoin
  1. Fast Fix Screen Replacement, Screen: étape 1, image 1 de 3 Fast Fix Screen Replacement, Screen: étape 1, image 2 de 3 Fast Fix Screen Replacement, Screen: étape 1, image 3 de 3
    • Slide both battery latches to release cover.
    • Remove battery.
  2. Fast Fix Screen Replacement: étape 2, image 1 de 2 Fast Fix Screen Replacement: étape 2, image 2 de 2
    • Remove the M2.5 X 5mm phillips screw for the CD drive.
    • Remove the CD drive.
  3. Fast Fix Screen Replacement: étape 3, image 1 de 2 Fast Fix Screen Replacement: étape 3, image 2 de 2
    • Loosen 2 screws on access door.
    • They cannot be removed
    • Remove the access door.
  4. Fast Fix Screen Replacement: étape 4, image 1 de 1
    • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
  5. Fast Fix Screen Replacement: étape 5, image 1 de 3 Fast Fix Screen Replacement: étape 5, image 2 de 3 Fast Fix Screen Replacement: étape 5, image 3 de 3
    • Use a small screwdriver to press in the keyboard latches.
    • Remove the keyboard.
    • Unplug the keyboard cable at the ZIF connection.
  6. Fast Fix Screen Replacement: étape 6, image 1 de 3 Fast Fix Screen Replacement: étape 6, image 2 de 3 Fast Fix Screen Replacement: étape 6, image 3 de 3
    • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
    • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
  7. Fast Fix Screen Replacement: étape 7, image 1 de 1
    • Use a small flat screwdriver to pry the palm-rest off of the computer.
  8. Fast Fix Screen Replacement: étape 8, image 1 de 3 Fast Fix Screen Replacement: étape 8, image 2 de 3 Fast Fix Screen Replacement: étape 8, image 3 de 3
    • Remove the wireless antenna
    • Remove the LCD cable
  9. Fast Fix Screen Replacement: étape 9, image 1 de 1
    • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
  10. Fast Fix Screen Replacement: étape 10, image 1 de 1
    • Pry off the LCD bevel using a small flat screwdriver.
  11. Fast Fix Screen Replacement: étape 11, image 1 de 1
    • Remove the 4 M2 X 3mm Philips LCD screws.
  12. Fast Fix Screen Replacement: étape 12, image 1 de 2 Fast Fix Screen Replacement: étape 12, image 2 de 2
    • Unplug the screen cable and remove the screen.
4 autres ont terminé cette réparation.
Carl Kangas
Membre depuis le 10/01/17
209 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team S3-G8, Galliah Fall 2017 Membre de l'équipe Michigan Tech, Team S3-G8, Galliah Fall 2017
MTU-GALLIAH-F17S3G8
1 membre
1 tutoriel rédigé
2 commentaires de tutoriel
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - Réponse
Hi, Did you ever fix this problem? I'm having the same issue.
Chris Terry -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 39
Total : 3,306
