Aller au contenu principal
Fast Fix Shower Curtain Permanent Rod Replacement
Ce dont vous avez besoin
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: étape 1, image 1 de 1
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: étape 2, image 1 de 2 Fast Fix Shower Curtain Permanent Rod Replacement: étape 2, image 2 de 2
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: étape 3, image 1 de 1
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: étape 4, image 1 de 1
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: étape 5, image 1 de 1
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: étape 6, image 1 de 2 Fast Fix Shower Curtain Permanent Rod Replacement: étape 6, image 2 de 2
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
To reassemble your device, follow these instructions in reverse order
Abdul-Jabbar Mohamed
Membre depuis le 09/15/20
134 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-16, O'Regan Winter 2022 Membre de l'équipe York University, Team 2-16, O'Regan Winter 2022
YORK-O'REGAN-W22S2G16
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 445
