Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Fender Starcaster Tuning Heads Replacement
Ce dont vous avez besoin
    1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: étape 1, image 1 de 3 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: étape 1, image 2 de 3 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: étape 1, image 3 de 3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      Demander à FixBot
      Ajouter un commentaire
    2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: étape 2, image 1 de 2 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: étape 2, image 2 de 2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      Demander à FixBot
    3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: étape 3, image 1 de 3 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: étape 3, image 2 de 3 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: étape 3, image 3 de 3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      Demander à FixBot
    1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: étape 4, image 1 de 2 Fender Starcaster Tuning Heads Replacement, Tuning Heads: étape 4, image 2 de 2
      • Using a wrench, remove the nuts around each tuning head post.
      Demander à FixBot
    2. Fender Starcaster Tuning Heads Replacement: étape 5, image 1 de 3 Fender Starcaster Tuning Heads Replacement: étape 5, image 2 de 3 Fender Starcaster Tuning Heads Replacement: étape 5, image 3 de 3
      • Next, remove the threaded retainer sleeve from each post.
      • Don't forget the washer.
      Demander à FixBot
    3. Fender Starcaster Tuning Heads Replacement: étape 6, image 1 de 2 Fender Starcaster Tuning Heads Replacement: étape 6, image 2 de 2
      • Next, remove the screws from the backside of each tuner.
      Demander à FixBot
    4. Fender Starcaster Tuning Heads Replacement: étape 7, image 1 de 2 Fender Starcaster Tuning Heads Replacement: étape 7, image 2 de 2
      • Finally, remove the tuning machine assembly from the headstock.
      Demander à FixBot
2 autres ont terminé cette réparation.
Christopher Hartigan
Membre depuis le 09/10/14
164 Réputation
5 tutoriels rédigés
Équipe
Pasco Hernando, Team 5-3, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 membres
10 tutoriels rédigés
3 commentaires de tutoriel
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - Réponse Partager
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - Réponse Partager
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 42
Total : 3,407
