Aller au contenu principal
First Act MA2039 Battery Replacement
Ce dont vous avez besoin
  1. First Act MA2039 Battery Replacement, Battery: étape 1, image 1 de 3 First Act MA2039 Battery Replacement, Battery: étape 1, image 2 de 3 First Act MA2039 Battery Replacement, Battery: étape 1, image 3 de 3
    • Press the bottom tab and lift the lid that is marked "9V Battery"
    • Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
    • Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
  2. First Act MA2039 Battery Replacement: étape 2, image 1 de 3 First Act MA2039 Battery Replacement: étape 2, image 2 de 3 First Act MA2039 Battery Replacement: étape 2, image 3 de 3
    • Insert a new, fully-charged 9-volt battery to the terminal connections.
    • Link the positive terminal (+) of the 9-volt battery to the positive connection.
    • Link the negative terminal (-) of the 9-volt battery to the negative connection.
    • Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
  3. First Act MA2039 Battery Replacement: étape 3, image 1 de 2 First Act MA2039 Battery Replacement: étape 3, image 2 de 2
    • Insert the 9-volt battery into the cartridge.
    • Press firmly to slide the battery into the cartridge, and close the tab to ensure the battery is secured.
    • Close the tab after the battery is secured, until the tab "clicks" into place.
  4. First Act MA2039 Battery Replacement: étape 4, image 1 de 2 First Act MA2039 Battery Replacement: étape 4, image 2 de 2
    • Make sure connections are secure and insert 9-volt batteries into the battery cartridges.
    • Close the tabs until you hear a click.
    • Now, try turning on the power switch. Get ready to rock & roll!
Luke VanBuskirk
Membre depuis le 04/05/18
279 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 630
