Aller au contenu principal
Fitbit Alta HR Battery Replacement
Ce dont vous avez besoin
  1. Fitbit Alta HR Battery Replacement, Remove straps: étape 1, image 1 de 2 Fitbit Alta HR Battery Replacement, Remove straps: étape 1, image 2 de 2
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: étape 2, image 1 de 1
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: étape 3, image 1 de 1
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: étape 4, image 1 de 1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: étape 5, image 1 de 1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: étape 6, image 1 de 2 Fitbit Alta HR Battery Replacement, Lift motherboard: étape 6, image 2 de 2
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: étape 7, image 1 de 1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
3 autres ont terminé cette réparation.
Wendy Sato
Membre depuis le 11/12/16
229 Réputation
1 tutoriel rédigé
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 88
Total : 1,934
