Aller au contenu principal
Fitbit Blaze Vibration Motor Replacement
Ce dont vous avez besoin
  1. Fitbit Blaze  Vibration Motor Replacement, Wristband: étape 1, image 1 de 2 Fitbit Blaze  Vibration Motor Replacement, Wristband: étape 1, image 2 de 2
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze  Vibration Motor Replacement: étape 2, image 1 de 1
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze  Vibration Motor Replacement: étape 3, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 3, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 3, image 3 de 3
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze  Vibration Motor Replacement, Display Frame: étape 4, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement, Display Frame: étape 4, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement, Display Frame: étape 4, image 3 de 3
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
  5. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: étape 5, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: étape 5, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: étape 5, image 3 de 3
    • Place device screen face down and locate the four screws attaching the back cover.
    • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
  6. Fitbit Blaze  Vibration Motor Replacement: étape 6, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 6, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 6, image 3 de 3
    • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
    • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
    • Insert and lift the plastic opening tool to release the ribbon.
    • Only a small force when lifting the plastic connector is needed to avoid damage.
  7. Fitbit Blaze  Vibration Motor Replacement: étape 7, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 7, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 7, image 3 de 3
    • Separate the back and set aside, locate the three screws attaching the motherboard.
    • Use a PH000 head or a PH000 screwdriver to remove the three screws.
  8. Fitbit Blaze  Vibration Motor Replacement: étape 8, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 8, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 8, image 3 de 3
    • Use a plastic spudger tool on the ribbons connected to the motherboard.
    • Insert the tool under the ribbon and lift to release the connection.
  9. Fitbit Blaze  Vibration Motor Replacement: étape 9, image 1 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 9, image 2 de 3 Fitbit Blaze  Vibration Motor Replacement: étape 9, image 3 de 3
    • Lift and push the motherboard to the side to uncover the 167mAh battery.
    • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
    • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
  10. Fitbit Blaze  Vibration Motor Replacement: étape 10, image 1 de 2 Fitbit Blaze  Vibration Motor Replacement: étape 10, image 2 de 2
    • Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
    • Desolder the connection to remove the motor component.
    • Follow this guide on how to solder and desolder connectors Soldering Guide
    • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
Adrian Borrego
Membre depuis le 02/20/17
2 242 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G3, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 membres
15 tutoriels rédigés
4 commentaires
anyone got a part number or a description of the motor that gets replaced. looking to do this and fix. thanks
Ben - Réponse
And how many destroyed “FitBit Blaze” are we going to see now?
tjhbob - Réponse
what kind of motor can you replace this with?
dbick - Réponse
Any idea what is the value of the C3 capacitor?
P J - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 28
Total : 3,183
