Aller au contenu principal
Fitbit Charge HR Screen Replacement
Ce dont vous avez besoin
  1. Fitbit Charge HR Screen Replacement, Screen: étape 1, image 1 de 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Screen Replacement: étape 2, image 1 de 3 Fitbit Charge HR Screen Replacement: étape 2, image 2 de 3 Fitbit Charge HR Screen Replacement: étape 2, image 3 de 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Screen Replacement: étape 3, image 1 de 2 Fitbit Charge HR Screen Replacement: étape 3, image 2 de 2
    • Remove the motherboard assembly from the device.
    • Flip the motherboard over so the screen is facing upwards.
  4. Fitbit Charge HR Screen Replacement: étape 4, image 1 de 3 Fitbit Charge HR Screen Replacement: étape 4, image 2 de 3 Fitbit Charge HR Screen Replacement: étape 4, image 3 de 3
    • Wedge a nylon spudger between the screen and the motherboard.
    • Gently pry the screen up and remove it from the motherboard.
    • Metal spudgers can puncture an unprotected battery and damage components like the motherboard. Always choose a tool that's ESD-safe, such as a nylon spudger or plastic opening tool.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 779
