Aller au contenu principal
Fitbit Surge Touchscreen Sensor Replacement
Ce dont vous avez besoin
  1. Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: étape 1, image 1 de 2 Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: étape 1, image 2 de 2
    • Unscrew all four black 3 mm screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Touchscreen Sensor Replacement: étape 2, image 1 de 3 Fitbit Surge Touchscreen Sensor Replacement: étape 2, image 2 de 3 Fitbit Surge Touchscreen Sensor Replacement: étape 2, image 3 de 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge Touchscreen Sensor Replacement: étape 3, image 1 de 2 Fitbit Surge Touchscreen Sensor Replacement: étape 3, image 2 de 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Touchscreen Sensor Replacement: étape 4, image 1 de 1
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Touchscreen Sensor Replacement: étape 5, image 1 de 2 Fitbit Surge Touchscreen Sensor Replacement: étape 5, image 2 de 2
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Touchscreen Sensor Replacement: étape 6, image 1 de 1
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: A spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
  7. Fitbit Surge Touchscreen Sensor Replacement: étape 7, image 1 de 1
    • Remove the touchscreen sensor using a spudger or your fingers.
    • Note: In this photo we removed the metal cover on the main PCB, but you do not need to remove it for this guide.
To reassemble your device, follow these instructions in reverse order. Keep in mind that the wristband will need to be cut for this repair and it cannot be reattached.
7 autres ont terminé cette réparation.
Angela Pitts
Membre depuis le 10/11/16
1 190 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 membres
4 tutoriels rédigés
5 commentaires de tutoriel
Is there a company that will perform this fix for me?
Terry Brown - Réponse
Where can I get a replacement sensor?
Francisco Cortez - Réponse
Isn’t any step missing in that instruction ?
Removing sensor will solve the issue ? How about adding new one ?
Erazm Gondoresku - Réponse
Hi, I didnt get the point, what should I do after removing sensor? Should I clean it or something? If I need to place a new one, maybe someone knows where to get one?
viktoras -
Is anyway I can buy the bus
Ajay Kumar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 34
Total : 2,984
