Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Pièces
Aucune pièce spécifiée.
  1. Manually eject the CD/DVD Drive
    • Manually eject the CD/DVD Drive
  2. There will be a gap in the middle of the CD/DVD tray. You will see 2 pulleys with a rubber belt. Use tweezers to carefully take the belt out.
    • There will be a gap in the middle of the CD/DVD tray. You will see 2 pulleys with a rubber belt. Use tweezers to carefully take the belt out.
  3. Take a Damp paper towel and clean any dust and dirt off of the rubber belt. Take a Damp paper towel and clean any dust and dirt off of the rubber belt.
    • Take a Damp paper towel and clean any dust and dirt off of the rubber belt.
  4. Using the tweezers again carefully put the rubber belt back in. I have found it easier to get it around the big pulley first then on the small pulley.
    • Using the tweezers again carefully put the rubber belt back in. I have found it easier to get it around the big pulley first then on the small pulley.
    • At this point turn the system on and test it. I have done this on several system that the drive just would not open and it has solved the issues.
Enjoy your Original Xbox again! Please sent me a message if you have any questions about the steps.
9 autre(s) ont terminé cette réparation.
Matt Weatherly
Membre depuis le 16/09/2012
923 Réputation
2 tutoriels rédigés
In my case cleaning the rubber band didn’t help - it has gotten too old and hard. I replaced it with the cheapest band from assorted set of rubber bands from the nearest supermarket, and it worked like a charm. Also the whole set cost me less than a dollar, so you may want to try that first before ordering overpriced "xbox" rubber bands from ebay.
Rathori - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 72
Total : 3,032
