Aller au contenu principal
Fixed Gear Bike Chainring Replacement
Ce dont vous avez besoin
  1. Fixed Gear Bike Chainring Replacement, Chainring: étape 1, image 1 de 2 Fixed Gear Bike Chainring Replacement, Chainring: étape 1, image 2 de 2
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: étape 2, image 1 de 2 Fixed Gear Bike Chainring Replacement: étape 2, image 2 de 2
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: étape 3, image 1 de 2 Fixed Gear Bike Chainring Replacement: étape 3, image 2 de 2
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: étape 4, image 1 de 1
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: étape 5, image 1 de 1
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Ligne d'arrivée
aljndro__
Membre depuis le 08/22/23
121 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membre de l'équipe CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 18
Total : 157
