Aller au contenu principal
Fixing a chair that squeaks
Ce dont vous avez besoin
  1. Fixing  a chair that squeaks, Fixing  a chair that squeaks: étape 1, image 1 de 2 Fixing  a chair that squeaks, Fixing  a chair that squeaks: étape 1, image 2 de 2
    • Examine chair to find source of squeaking. It can be from the legs, back, or the seat.
    • To find the source of squeaking you can flip the chair and place it upside down on the ground and observe how the legs are attached to the seat. You can grab each leg with your hand(s) and move it around to see if you can find the squeak. Another way you can check for squeaks is by sitting in the chair and wiggling to locate the squeak.
  2. Fixing  a chair that squeaks: étape 2, image 1 de 1
    • Grab your hex wrench and/or screwdriver.
    • Use the head for the screwdriver that best fits your screws/bolts and the same goes for the allen wrench.
  3. Fixing  a chair that squeaks: étape 3, image 1 de 2 Fixing  a chair that squeaks: étape 3, image 2 de 2
    • Using the hex wrench and/or screwdriver tighten any loose screws underneath the chair and check again for squeaking.
  4. Fixing  a chair that squeaks: étape 4, image 1 de 3 Fixing  a chair that squeaks: étape 4, image 2 de 3 Fixing  a chair that squeaks: étape 4, image 3 de 3
    • If the chair is still squeaking remove all screws from the leg(s) that is/are squeaking.
    • The dowel is now exposed.
    • Once you remove the screws you will be able to freely move the leg and any additional wood attached to it. Removing the additional wood will expose dowels, be sure to note where you removed the wood and position so you can correctly reassemble it later.
  5. Fixing  a chair that squeaks: étape 5, image 1 de 3 Fixing  a chair that squeaks: étape 5, image 2 de 3 Fixing  a chair that squeaks: étape 5, image 3 de 3
    • The wooden dowels are exposed after removing all the screws.
    • Grab your wood glue.
  6. Fixing  a chair that squeaks: étape 6, image 1 de 3 Fixing  a chair that squeaks: étape 6, image 2 de 3 Fixing  a chair that squeaks: étape 6, image 3 de 3
    • Apply the wood glue where the dowels are located, be sure to get the glue inside the holes.
    • Try to do this step as clean as you can, it can get very messy and wood glue can ruin wood.
  7. Fixing  a chair that squeaks: étape 7, image 1 de 2 Fixing  a chair that squeaks: étape 7, image 2 de 2
    • Place the wood you removed from the chair back to the appropriate regions of the chair.
  8. Fixing  a chair that squeaks: étape 8, image 1 de 2 Fixing  a chair that squeaks: étape 8, image 2 de 2
    • Once you’ve placed all wood back in their correct positions grab your hex wrench/screwdriver, and cloth.
    • Wet the cloth and and remove any excess glue from the chair.
    • DO NOT let the glue dry as it will ruin your wood.
    • Use the correct head size and allen wrench for your screws/bolts.
  9. Fixing  a chair that squeaks: étape 9, image 1 de 2 Fixing  a chair that squeaks: étape 9, image 2 de 2
    • Put the screws back into the chair using the screwdriver/hex wrench.
  10. Fixing  a chair that squeaks: étape 10, image 1 de 1
    • Grab your clamp(s) for the chair.
  11. Fixing  a chair that squeaks: étape 11, image 1 de 3 Fixing  a chair that squeaks: étape 11, image 2 de 3 Fixing  a chair that squeaks: étape 11, image 3 de 3
    • Secure the clamp(s) onto the chair and occasionally check for dripping glue.
    • Let the chair sit with clamp(s) on for a minimum of 24 hours.
    • DO NOT use the chair while clamps are attached and glue is wet, the glue will be misplaced and the chair will still squeak.
    • You have now completed the necessary steps to rid the terrible squeaks from your wooden chairs.
    • If you have more wooden chairs that squeak you will have to repeat this procedure.
    • Thank you for reading!
To fix your squeaky chair device, follow these simple instructions.
3 autres ont terminé cette réparation.
Samantha Aguilar
Membre depuis le 01/23/20
286 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 membres
28 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 59
30 derniers jours : 186
Total : 4,732
