Aller au contenu principal
Fixing a Broken Shelf in a Refrigerator
Ce dont vous avez besoin
  1. Fixing a Broken Shelf in a Refrigerator, Fixing a Broken Shelf in a Refrigerator: étape 1, image 1 de 2 Fixing a Broken Shelf in a Refrigerator, Fixing a Broken Shelf in a Refrigerator: étape 1, image 2 de 2
    • Open the refrigerator door.
    • Empty any items on the shelf bar.
  2. Fixing a Broken Shelf in a Refrigerator: étape 2, image 1 de 2 Fixing a Broken Shelf in a Refrigerator: étape 2, image 2 de 2
    • Grasp the shelf on each end and lift each straight up.
    • Disengage the two hooks from the molded tabs on the liner.
    • Inspect to make sure they are not damaged.
  3. Fixing a Broken Shelf in a Refrigerator: étape 3, image 1 de 2 Fixing a Broken Shelf in a Refrigerator: étape 3, image 2 de 2
    • Remove any tape that was holding the shelf bar together.
  4. Fixing a Broken Shelf in a Refrigerator: étape 4, image 1 de 1
    • Clean the shelf using dish detergent and water.
    • Remove any tape residue with a scouring pad.
  5. Fixing a Broken Shelf in a Refrigerator: étape 5, image 1 de 1
    • Take a paper towel or towel and dry off the shelf bar.
  6. Fixing a Broken Shelf in a Refrigerator: étape 6, image 1 de 1
    • Try fitting the pieces together to make sure that the pieces are intact and that nothing is missing.
  7. Fixing a Broken Shelf in a Refrigerator: étape 7, image 1 de 1
    • Spread the Loctite 60 Sec Universal glue along the edge of both sides of the bar.
  8. Fixing a Broken Shelf in a Refrigerator: étape 8, image 1 de 2 Fixing a Broken Shelf in a Refrigerator: étape 8, image 2 de 2
    • Carefully join the pieces together and hold them tight for two minutes.
    • Tape the pieces together with blue painter’s tape.
    • The tape comes off easily without leaving any gluey residue.
  9. Fixing a Broken Shelf in a Refrigerator: étape 9, image 1 de 1
    • Leave the shelf to dry for ten minutes.
    • Once the glue dries, take the blue painter’s tape off.
  10. Fixing a Broken Shelf in a Refrigerator: étape 10, image 1 de 2 Fixing a Broken Shelf in a Refrigerator: étape 10, image 2 de 2
    • Take the shelf bar and line the hooks over the tabs and press it firmly back into the refrigerator door.
    • Do not place too much pressure on the shelf, so it won't crack again.
After completing all the steps for repairing the refrigerator shelf bar, the refrigerator shelf bar will be all new. However, be gentle with the shelf bar. Do not place much pressure on it or it will break again.
Tatiana Jeune
Membre depuis le 01/12/19
217 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019
USFSM-STEWART-S19S1G1
18 membres
29 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 54
Total : 10,831
