Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
You recently bought a cassette-to-aux adaptor at a local drug store so you can play music from your MP3 player in your older car. However, when you insert the cassette into the older car's cassette player, the cassette player flips the cassette continuously. This guide will show you the steps to fixing the auto flip problem.
Photo credit: Alexander Bohlen Photography
  1. Unscrew all the screws around the cassette tape box. Place screws somewhere safe so you do not lose them. Models, screw locations, and screw sizes may vary.
    • Unscrew all the screws around the cassette tape box.
    • Place screws somewhere safe so you do not lose them.
    • Models, screw locations, and screw sizes may vary.
  2. Slowly remove the cover of the cassette box. Take a photo of the insides of the cassette box so it can guide when you are reassembling the cassette box. Do not worry if you open the cassette box upside down (shown in 2nd photo) it is easy to correct; simply put the case back on, flip it over (shown in 3rd photo) and pull the new front side off (1st photo again).
    • Slowly remove the cover of the cassette box.
    • Take a photo of the insides of the cassette box so it can guide when you are reassembling the cassette box.
    • Do not worry if you open the cassette box upside down (shown in 2nd photo) it is easy to correct; simply put the case back on, flip it over (shown in 3rd photo) and pull the new front side off (1st photo again).
  3. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  4. Remove the auto flip mechanism located on the top corner. Do not throw this away; you may have to reinstall it if you want to use a different cassette player.
    • Remove the auto flip mechanism located on the top corner.
    • Do not throw this away; you may have to reinstall it if you want to use a different cassette player.
  5. Make sure all electrical circuitry and gears that were not removed are in their correct location. Any other gears inside the cassette box, really aren't necessary. So feel free to remove them if the cassette is making too much noise (shown in 2nd photo).
    • Make sure all electrical circuitry and gears that were not removed are in their correct location.
    • Any other gears inside the cassette box, really aren't necessary. So feel free to remove them if the cassette is making too much noise (shown in 2nd photo).
    • Edit 3/14/2019: All cars are different. Many people in the comments have had luck keeping the center gears in the cassette and removing the interface gears. And also vice versa. Play around with it! If you can get it to work, awesome! If not, then try something else. Don't give up until you have your music playing in your car! Cheers!
To reassemble your device, follow these instructions in reverse order, but do not replace the gears you removed.
13 autre(s) ont terminé cette réparation.
Jonathan Falco
Membre depuis le 24/02/2015
621 Réputation
2 tutoriels rédigés
18 commentaires
that $@$* done work all it did was keep swtiching sides even more without the gears in it.............
pvmxfgt - Réponse
It might have to do with the stereo in your car. When I made this guide, I was experiencing the problem in my 2000 Nissan Xterra, but my own guide didn’t help. Some stereos are just broken, like mine was. To be completely honest, I had no idea this guide would even work for people, like it is. Sorry it didn’t help fix your problem. I would suggest getting a new stereo installed in your car. If it’s an older car, you may be able to do it <$100 for a decent stereo. Cheers mate!
Jonathan Falco -
Worked perfectly for me, thanks for putting this guide together.
Patrick Osborne - Réponse
You’re welcome!
Jonathan Falco -
Worked for me. I used to buy these things new every couple of years. Glad I did not throw all the old ones out
Peter K - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 18
7 derniers jours : 133
30 derniers jours : 566
Total : 64,251
