Aller au contenu principal
Fixing the Phantom Double Clicking on Logitech MX Anywhere 3
  1. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Tools: étape 1, image 1 de 1
    • Those are tools you need.
    • Knife and screwdriver are for opening up the mouse. You may also need an iron (which will help you to soften the glue at the mouse feet).
    • Dust blower, lubricant and tissue are for fixing the click.
  2. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Open up the mouse: étape 2, image 1 de 2 Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Open up the mouse: étape 2, image 2 de 2
    • Please follow the instructions in "How to Open Your Logitech MX Anywhere 3" to open up the mouse. It looks like this when you're done.
    • You can heat up an iron and place it on the mouse feet to soften the glue. Be careful when using the iron.
  3. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Disconnect the cables.: étape 3, image 1 de 1
    • Disconnect the cables at the locations marked in red and orange circles. In any case, handle with care to avoid damage to the cables.
    • Cables in red circles can be easily unlocked by lifting the white pins up. You, however, may need to use some force on the orange one.
  4. Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Fix the click: étape 4, image 1 de 3 Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Fix the click: étape 4, image 2 de 3 Fixing the Phantom Double Clicking on Logitech MX Anywhere 3, Fix the click: étape 4, image 3 de 3
    • Those are tools you need for this last step.
    • Use the dust blower to blow the dust away.
    • Then, apply some lubricant to the locations marked in blue circles. Make sure you spray the lubricant into the clicking pieces in both the lower and upper parts of the mouse.
    • Make a few clicks and scroll the wheel to ensure that everything works smoothly.
    • Use the tissue to wipe away excessive lubricant before reassembling the mouse.
garfieldknight
Membre depuis le 02/13/19
953 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 54
30 derniers jours : 269
Total : 659
