Introduction
Fan cleaning is part of the preventive maintenance of a 3d printer. Approximately every 300 printing hours, disassemble and clean it to prevent fan blockages and subsequent printing errors. This guide can also be applied to fan replacement.
Ce dont vous avez besoin
Remove the three screws on the extruder top with a 2.5 Allen key or an appropriate screwdriver bit
Gently lift up the extruder cover
Using a spudger, disconnect the fan connector
Route the cable to free it
The fan can now be removed from the extruder. If you need to replace it, just follow the steps in reverse order with the new fan
If you are cleaning the fan, release the three clips holding it together with a spudger
