Aller au contenu principal
DJI Phantom 3 Advanced Flight Controller Replacement
Ce dont vous avez besoin
  1. DJI Phantom 3 Advanced Flight Controller Replacement, Battery: étape 1, image 1 de 2 DJI Phantom 3 Advanced Flight Controller Replacement, Battery: étape 1, image 2 de 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Flight Controller Replacement: étape 2, image 1 de 2 DJI Phantom 3 Advanced Flight Controller Replacement: étape 2, image 2 de 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Flight Controller Replacement, Cover: étape 3, image 1 de 1
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Flight Controller Replacement: étape 4, image 1 de 1
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Flight Controller Replacement: étape 5, image 1 de 2 DJI Phantom 3 Advanced Flight Controller Replacement: étape 5, image 2 de 2
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Flight Controller Replacement: étape 6, image 1 de 2 DJI Phantom 3 Advanced Flight Controller Replacement: étape 6, image 2 de 2
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Flight Controller Replacement: étape 7, image 1 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 7, image 2 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 7, image 3 de 3
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Flight Controller Replacement: étape 8, image 1 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 8, image 2 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 8, image 3 de 3
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
  9. DJI Phantom 3 Advanced Flight Controller Replacement, Flight Controller: étape 9, image 1 de 1
    • Locate the five ribbon cables that need to be disconnected from the control board.
    • Locate the red and black battery wires.
    • Follow the three wires from each motor and the three wires from each LED to where they connect on the control board.
  10. DJI Phantom 3 Advanced Flight Controller Replacement: étape 10, image 1 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 10, image 2 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 10, image 3 de 3
    • Use a plastic opening tool to remove the glue that covers the motor and LED wires. Use a metal opening tool if necessary.
    • Desolder the six motor and LED wires where they connect on the flight controller for each arm. Refer to the Desoldering Guide on how to desolder.
    • Desolder the battery wires.
  11. DJI Phantom 3 Advanced Flight Controller Replacement: étape 11, image 1 de 2 DJI Phantom 3 Advanced Flight Controller Replacement: étape 11, image 2 de 2
    • Remove the cable next to where the battery wires were connected. Pinch and hold the top of the connector, then pull it out.
  12. DJI Phantom 3 Advanced Flight Controller Replacement: étape 12, image 1 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 12, image 2 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 12, image 3 de 3
    • Remove the black ribbon cable and the 3-wire cable next to it. Press the small tab on the ribbon cable connector and pull it out.
  13. DJI Phantom 3 Advanced Flight Controller Replacement: étape 13, image 1 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 13, image 2 de 3 DJI Phantom 3 Advanced Flight Controller Replacement: étape 13, image 3 de 3
    • Locate the ribbon cable that is next to the word "Front" on the flight controller.
    • Remove the small cable next to the ribbon cable by pinching on the side tab and pulling up on the connector. It has black, red and yellow wires.
    • Remove the black band from the ribbon cable.
    • Remove the ribbon cable by pinching on the side tab and pulling up on the connector.
  14. DJI Phantom 3 Advanced Flight Controller Replacement: étape 14, image 1 de 2 DJI Phantom 3 Advanced Flight Controller Replacement: étape 14, image 2 de 2
    • Remove the four 6.5mm long 2mm screws with a philips head 00 screwdriver.
    • Remove the flight controller now by slowly pulling if off of the frame.
11 autres ont terminé cette réparation.
Robert Comstock
Membre depuis le 10/06/16
421 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-2, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 membres
12 tutoriels rédigés
2 commentaires
Very clear and helpful. Thank You.
Herb - Réponse
Excellent with great visuals. Can really see what to do
Leo Miller - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 33
Total : 6,871
