Aller au contenu principal
Flipper Zero Display Replacement
Ce dont vous avez besoin
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero Display Replacement, Remove the microSD card: étape 2, image 1 de 1
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero Display Replacement, Remove the screws: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    Phillips #1 Screwdriver
    $5.49
    J'achète
    • Use a PH1 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero Display Replacement, Open the back cover: étape 4, image 1 de 3 Flipper Zero Display Replacement, Open the back cover: étape 4, image 2 de 3 Flipper Zero Display Replacement, Open the back cover: étape 4, image 3 de 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero Display Replacement, Seperate the chassis from the top cover: étape 5, image 1 de 2 Flipper Zero Display Replacement, Seperate the chassis from the top cover: étape 5, image 2 de 2
    Phillips #0 Screwdriver
    $5.49
    J'achète
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero Display Replacement, Disconnect the battery: étape 6, image 1 de 1
    Spudger
    $3.99
    J'achète
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero Display Replacement, Disconnect the ribbon cable: étape 7, image 1 de 1
    iFixit Opening Picks (Set of 6)
    J'achète
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero Display Replacement, Release the battery chassis: étape 8, image 1 de 2 Flipper Zero Display Replacement, Release the battery chassis: étape 8, image 2 de 2
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
  8. Flipper Zero Display Replacement, Unscrew the the button chassis: étape 9, image 1 de 1
    $5.49
    J'achète
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  9. Flipper Zero Display Replacement, Seperate the button chassis: étape 10, image 1 de 3 Flipper Zero Display Replacement, Seperate the button chassis: étape 10, image 2 de 3 Flipper Zero Display Replacement, Seperate the button chassis: étape 10, image 3 de 3
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
  10. Flipper Zero Display Replacement, Disconnect the screen: étape 11, image 1 de 2 Flipper Zero Display Replacement, Disconnect the screen: étape 11, image 2 de 2
    J'achète
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  11. Flipper Zero Display Replacement, Desolder the screen: étape 12, image 1 de 1
    • To remove the screen you need to desolder two contacts.
    • See this guide on how to solder and desolder connections.
10 autres ont terminé cette réparation.
Sebastian
Membre depuis le 08/19/18
19 069 Réputation
60 tutoriels rédigés
Équipe
German Translators Membre de l'équipe German Translators
Community
23 membres
727 tutoriels rédigés
2 commentaires
Everything worked fine following this guide. Thank you for the help. In my case was just the glass that was broken, so at the end, i didnt needed to desolder. Just removed the glass with the Plastic pick and worked perfectly. Thank you again for the help.
arthureldo - Réponse
Where did you find a replacement glass?
Ben Durrant -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 133
30 derniers jours : 744
Total : 9,599
