Aller au contenu principal
Fluid Change and Brake Bleeding
Ce dont vous avez besoin
  1. Fluid Change and Brake Bleeding, Fluid Change and Brake Bleeding: étape 1, image 1 de 2 Fluid Change and Brake Bleeding, Fluid Change and Brake Bleeding: étape 1, image 2 de 2
    • Remove the wheel of the calipers you are going to bleed, and remove the brake pads.
    • Install Avid® brake block.
    • You can substitute a 10mm wide block, such as a hex key, if necessary.
  2. Fluid Change and Brake Bleeding, Check the reach adjustment.: étape 2, image 1 de 1
    • Levers set for a long reach may have the reservoir closed and will not permit bleeding.
    • Measure from the center of handlebar to the tip of brake lever. The distance should be no more than 80 mm.
  3. Fluid Change and Brake Bleeding: étape 3, image 1 de 1
    • If present, set the volume of the caliper system with the adjusting knobs on the lever.
    • On the right-hand lever, turn knob completely counterclockwise, then back clockwise one turn.
    • On the left-hand lever: turn knob completely clockwise, then back counter-clockwise one turn.
    • Rotate the bike and brake levers as necessary to ensure an upward flow from the caliper to the lever bleed screw.
    • Loosen brake lever bolts just enough to allow you to rotate levers to different angles.
    • Install Avid® caliper piston block.
    • This keeps the pistons in position. If pistons were to move, the system would overfill with brake fluid.
    • If no block is available. substitute a 10 mm hex key.
  4. Fluid Change and Brake Bleeding: étape 6, image 1 de 1
    • Check to make sure the half-full syringe is free of bubbles and that the tubing clip is closed.
    • At the caliper, remove bleed port screw using a T10 Torx driver.
    • Screw is located in the center of the banjo bolt that attaches the hose to the caliper.
    • Remove port screw and insert the syringe into the fitting.
    • Remove screw front the bleed port near the brake lever.
    • Thread in the quarter-full bleed syringe.
    • This syringe will accept the overflow from the caliper syringe during the bleeding process.
  5. Fluid Change and Brake Bleeding: étape 8, image 1 de 2 Fluid Change and Brake Bleeding: étape 8, image 2 de 2
    • Open tubing clamp clips on both syringes.
    • Hold the lower syringe to help prevent any air from entering the caliper body.
    • Push the lower syringe plunger to move fluid through the system and out into the lever syringe.
    • Inspect for air bubbles.
    • Inspect for dirty or contaminated fluid
    • Push lower syringe plunger until mostly empty of fluid.
    • Do not fully empty syringe.
    • Close tubing clip on lever syringe.
    • Leave caliper syringe tubing clip open.
  6. Fluid Change and Brake Bleeding: étape 10, image 1 de 1
    • Pull brake lever against the handlebar.
    • Secure to the lever to the bar with a toe strap or rubber band.
  7. Fluid Change and Brake Bleeding: étape 11, image 1 de 1
    • At lower caliper syringe, push plunger gently to pressurize the system, and then pull back on the plunger.
    • Repeat this process three or four times to pressurize and then apply a vacuum to the caliper.
    • Inspect for any air coming back into syringe.
    • Leave caliper syringe open.
  8. Fluid Change and Brake Bleeding: étape 12, image 1 de 1
    • Remove the strap holding lever, but hold it against the bar with your hand.
    • Push caliper syringe plunger and allow the lever to slowly move away from the bar as fluid flows to the caliper.
    • Close the tubing clip at caliper syringe.
    • Unthread caliper syringe and reinstall bleed port screw.
    • Clean off any fluid with alcohol or soapy water.
  9. Fluid Change and Brake Bleeding: étape 14, image 1 de 1
    • Open tubing clamp of syringe at lever.
    • Pull back on the plunger to create a vacuum, then push the plunger down.
    • Pull the brake lever slightly and allow it to snap back to help purge any bubbles remaining in lever body.
    • Repeat this process 10 times, or until no more bubbles appear in the tubing.
    • Push the plunger gently as lever syringe is unthreaded from lever.
    • Remove the syringe and install the bleed port screw.
    • Clean up any spilled fluid with alcohol or soapy water.
    • Reinstall brake pads and wheel.
    • Pull the brake lever to bring the pistons to the rotor.
    • Lever should feel firm when pulled with force.
    • Repeat bleed if necessary.
    • Empty the syringes into an appropriate container and store them with their clamps open.
Park Tool
Membre depuis le 01/21/14
1 211 Réputation
1 tutoriel rédigé
Équipe
Park Tool Membre de l'équipe Park Tool
Community
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 8
Total : 439
