Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will assist you to change the battery on a fob watch. These watches are worn on the chest, and are often used by nurses and other healthcare professionals to easily see the time, aid in clinical assessment, and to maintain infection control by avoiding the use of a wristwatch.
The battery in a fob watch can be changed easily.
Pièces
Aucune pièce spécifiée.
  1. Remove the watch from the silicon casing and turn the watch over. Locate the small indent on  the edge of the back plate.
    • Remove the watch from the silicon casing and turn the watch over.
    • Locate the small indent on the edge of the back plate.
  2. Wedge the tip of a Jimmy underneath the indent to lift off the back plate. Use a safe tool to avoid accidents. Use a safe tool to avoid accidents.
    • Wedge the tip of a Jimmy underneath the indent to lift off the back plate.
    • Use a safe tool to avoid accidents.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Insert a spudger underneath the white plastic that holds the movement in place. Lift the plastic up and remove.
    • Insert a spudger underneath the white plastic that holds the movement in place.
    • Lift the plastic up and remove.
    • Use an ESD safe tool near the battery or other internal components.
  5. Locate the small circle battery Wedge the tip of the spudger underneath the small circle battery and lift it out.
    • Locate the small circle battery
    • Wedge the tip of the spudger underneath the small circle battery and lift it out.
    • Do not use a knife or other metal tool with a battery or other internal component as this could cause damage.
  6. Insert the new battery. Insert the new battery.
    • Insert the new battery.
To reassemble your watch, follow these instructions in reverse order. Pull out and turn the dial on the side of the watch to adjust the time.
Lilli Morgan
Membre depuis le 05/03/2019
121 Réputation
1 tutoriel rédigé
Équipe
Massey University, Team S1-G1, Rauch Fall 2019 Membre de l'équipe Massey University, Team S1-G1, Rauch Fall 2019
MUNZ-RAUCH-F19S1G1
1 membre
1 tutoriel rédigé
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 6
7 derniers jours : 42
30 derniers jours : 229
Total : 1,043
