Aller au contenu principal
Ford Focus Door Interior dome light assembly Replacement
Ce dont vous avez besoin
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: étape 1, image 1 de 2 Ford Focus Door Interior dome light assembly Replacement, interior dome light: étape 1, image 2 de 2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: étape 2, image 1 de 2 Ford Focus Door Interior dome light assembly Replacement: étape 2, image 2 de 2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: étape 3, image 1 de 2 Ford Focus Door Interior dome light assembly Replacement: étape 3, image 2 de 2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: étape 4, image 1 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 4, image 2 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 4, image 3 de 3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: étape 5, image 1 de 2 Ford Focus Door Interior dome light assembly Replacement: étape 5, image 2 de 2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: étape 6, image 1 de 2 Ford Focus Door Interior dome light assembly Replacement: étape 6, image 2 de 2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: étape 7, image 1 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 7, image 2 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 7, image 3 de 3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: étape 8, image 1 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 8, image 2 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 8, image 3 de 3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: étape 9, image 1 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 9, image 2 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 9, image 3 de 3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: étape 10, image 1 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 10, image 2 de 3 Ford Focus Door Interior dome light assembly Replacement: étape 10, image 3 de 3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: étape 11, image 1 de 2 Ford Focus Door Interior dome light assembly Replacement: étape 11, image 2 de 2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
5 autres ont terminé cette réparation.
Cassidy
Membre depuis le 03/21/16
241 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 1-11, Lauer Spring 2016 Membre de l'équipe Michigan Tech, Team 1-11, Lauer Spring 2016
MTU-LAUER-S16S1G11
1 membre
2 tutoriels rédigés
Un commentaire
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 69
Total : 23,187
