Introduction
After too many charging cycles, the battery's capacity will be decreased. This is true for any Lithium-ion battery. Luckily the replacement of the battery in this device is very simple.
Ce dont vous avez besoin
To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
Remove the four #0 15mm screws to release the battery housing from the case.
