Aller au contenu principal
Fosera Scandle 200 Motherboard Removal
Ce dont vous avez besoin
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: étape 1, image 1 de 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: étape 2, image 1 de 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: étape 3, image 1 de 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: étape 4, image 1 de 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: étape 5, image 1 de 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Ligne d'arrivée
Vladislav Ignatov
Membre depuis le 09/23/14
585 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 12-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 253
