Aller au contenu principal
Fosera Scandle 200 Power Switch Replacement
Ce dont vous avez besoin
  1. Fosera Scandle 200 Power Switch Replacement, Motherboard Removal: étape 1, image 1 de 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Power Switch Replacement: étape 2, image 1 de 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Power Switch Replacement: étape 3, image 1 de 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Power Switch Replacement: étape 4, image 1 de 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Power Switch Replacement: étape 5, image 1 de 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Fosera Scandle 200 Power Switch Replacement, Power Switch: étape 6, image 1 de 1
    • Locate the Power Switch, and examine the area underneath the yellow plastic.
    • If you find something obstructing the movement, and you can remove it, you're done! If not, proceed with the replacement.
  7. Fosera Scandle 200 Power Switch Replacement: étape 7, image 1 de 1
    • Locate the three prong connectors for the switch on the back of the motherboard. The correct prongs will be right under the print which reads, "Scandle0410 REV.07"
  8. Fosera Scandle 200 Power Switch Replacement: étape 8, image 1 de 1
    • The soldering iron WILL be hot! Don't touch the iron's tip or any parts which have recently been in contact with the iron.
    • The solder around all three prong connectors will need to be melted individually. Push the prongs out with the soldering iron as the solder melts.
  9. Fosera Scandle 200 Power Switch Replacement: étape 9, image 1 de 1
    • Use the flat end of the spudger to pry the power switch from the motherboard. If the switch is still secured, use the pointed end of the spudger to poke the prongs out from the back.
2 autres ont terminé cette réparation.
Jared
Membre depuis le 09/23/14
190 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 12-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 165
