Introduction
Did you lose a screw in your Framework Desktop? Fear not! Follow this guide to replace your missing screws with the Framework Desktop Fastener Kit.
Ce dont vous avez besoin
Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
Two large screws labeled "M6 ring screws"
Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
If you need help, contact Framework support.
