Aller au contenu principal
Framework Desktop RTC Battery Replacement
Ce dont vous avez besoin
  1. Framework Desktop RTC Battery Replacement, Power down your Desktop: étape 1, image 1 de 3 Framework Desktop RTC Battery Replacement, Power down your Desktop: étape 1, image 2 de 3 Framework Desktop RTC Battery Replacement, Power down your Desktop: étape 1, image 3 de 3
    • Before you begin repairs, shut down your desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
    • Make sure your Framework Desktop Screwdriver has the Phillips #2 bit (labeled as PH2) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Desktop RTC Battery Replacement, Remove the Handle: étape 2, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the Handle: étape 2, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the Handle: étape 2, image 3 de 3
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. Framework Desktop RTC Battery Replacement, Remove the Top Panel screws: étape 3, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the Top Panel screws: étape 3, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the Top Panel screws: étape 3, image 3 de 3
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. Framework Desktop RTC Battery Replacement: étape 4, image 1 de 3 Framework Desktop RTC Battery Replacement: étape 4, image 2 de 3 Framework Desktop RTC Battery Replacement: étape 4, image 3 de 3
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. Framework Desktop RTC Battery Replacement: étape 5, image 1 de 3 Framework Desktop RTC Battery Replacement: étape 5, image 2 de 3 Framework Desktop RTC Battery Replacement: étape 5, image 3 de 3
    • Repeat the same procedure for the other Top Panel screw.
  6. Framework Desktop RTC Battery Replacement, Remove the Top Panel: étape 6, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the Top Panel: étape 6, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the Top Panel: étape 6, image 3 de 3
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. Framework Desktop RTC Battery Replacement, Remove the Left Panel: étape 7, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the Left Panel: étape 7, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the Left Panel: étape 7, image 3 de 3
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
  8. Framework Desktop RTC Battery Replacement, Lay down the Desktop: étape 8, image 1 de 2 Framework Desktop RTC Battery Replacement, Lay down the Desktop: étape 8, image 2 de 2
    • Lay down the Desktop on its side so the fan is facing upward.
  9. Framework Desktop RTC Battery Replacement, Disconnect the fan: étape 9, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the fan: étape 9, image 2 de 2
    • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
  10. Framework Desktop RTC Battery Replacement: étape 10, image 1 de 2 Framework Desktop RTC Battery Replacement: étape 10, image 2 de 2
    • If you aren't using an RGB fan, then skip this step.
    • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
  11. Framework Desktop RTC Battery Replacement, Remove the CPU fan screws: étape 11, image 1 de 2 Framework Desktop RTC Battery Replacement, Remove the CPU fan screws: étape 11, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
  12. Framework Desktop RTC Battery Replacement, Remove the fan duct: étape 12, image 1 de 2 Framework Desktop RTC Battery Replacement, Remove the fan duct: étape 12, image 2 de 2
    • Lift the fan duct off the fan and remove it.
  13. Framework Desktop RTC Battery Replacement, Remove the fan: étape 13, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the fan: étape 13, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the fan: étape 13, image 3 de 3
    • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
  14. Framework Desktop RTC Battery Replacement, Disconnect the top Expansion Card cable: étape 14, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the top Expansion Card cable: étape 14, image 2 de 2
    • Pull the top Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  15. Framework Desktop RTC Battery Replacement, Disconnect the main power cable: étape 15, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the main power cable: étape 15, image 2 de 2
    • While squeezing the clip on the main power cable, pull it straight up and out of its socket to disconnect it.
  16. Framework Desktop RTC Battery Replacement, Disconnect the CPU power cable: étape 16, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the CPU power cable: étape 16, image 2 de 2
    • While squeezing the clip on the CPU power cable, pull it straight up and out of its socket to disconnect it.
  17. Framework Desktop RTC Battery Replacement, Disconnect the bottom Expansion Card cable: étape 17, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the bottom Expansion Card cable: étape 17, image 2 de 2
    • Pull the bottom Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  18. Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 18, image 1 de 2 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 18, image 2 de 2
    • Lift the Desktop so it stands upright on your work surface.
  19. Framework Desktop RTC Battery Replacement, Remove the Right Panel: étape 19, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the Right Panel: étape 19, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the Right Panel: étape 19, image 3 de 3
    • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
    • Remove the Right Panel.
  20. Framework Desktop RTC Battery Replacement, Remove the top plate screws: étape 20, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the top plate screws: étape 20, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the top plate screws: étape 20, image 3 de 3
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
  21. Framework Desktop RTC Battery Replacement, Remove the top plate: étape 21, image 1 de 2 Framework Desktop RTC Battery Replacement, Remove the top plate: étape 21, image 2 de 2
    • Lift the top plate off the Desktop and remove it.
  22. Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 22, image 1 de 2 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 22, image 2 de 2
    • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
  23. Framework Desktop RTC Battery Replacement, Remove the Wi-Fi Module screw: étape 23, image 1 de 2 Framework Desktop RTC Battery Replacement, Remove the Wi-Fi Module screw: étape 23, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  24. Framework Desktop RTC Battery Replacement, Disconnect the Wi-Fi module: étape 24, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the Wi-Fi module: étape 24, image 2 de 2
    • Grip the Wi-Fi module by its edges and pull it straight out of its socket.
  25. Framework Desktop RTC Battery Replacement, Reposition the Wi-Fi module: étape 25, image 1 de 3 Framework Desktop RTC Battery Replacement, Reposition the Wi-Fi module: étape 25, image 2 de 3 Framework Desktop RTC Battery Replacement, Reposition the Wi-Fi module: étape 25, image 3 de 3
    • Move the Wi-Fi module towards the center of the Mainboard to keep it out of the way.
  26. Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 26, image 1 de 3 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 26, image 2 de 3 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 26, image 3 de 3
    • Rotate the Desktop onto its right side so the Mainboard is facing upward.
  27. Framework Desktop RTC Battery Replacement, Disconnect the power button: étape 27, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the power button: étape 27, image 2 de 2
    • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
  28. Framework Desktop RTC Battery Replacement, Remove the Mainboard screws: étape 28, image 1 de 2 Framework Desktop RTC Battery Replacement, Remove the Mainboard screws: étape 28, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws securing the Mainboard.
  29. Framework Desktop RTC Battery Replacement, Remove the Mainboard: étape 29, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the Mainboard: étape 29, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the Mainboard: étape 29, image 3 de 3
    • Grab the Mainboard by its heatsink and pull it towards the front of the Desktop to slide it out of the rear port cutout.
    • Slide the Mainboard towards the top of the Desktop to remove it from the chassis.
  30. Framework Desktop RTC Battery Replacement, Place the Mainboard: étape 30, image 1 de 2 Framework Desktop RTC Battery Replacement, Place the Mainboard: étape 30, image 2 de 2
    • Place the Mainboard on your work surface with its heatsink resting on a soft, clean cloth.
  31. Framework Desktop RTC Battery Replacement, Loosen the RTC battery cover screws: étape 31, image 1 de 2 Framework Desktop RTC Battery Replacement, Loosen the RTC battery cover screws: étape 31, image 2 de 2
    • Use your Framework Desktop Screwdriver to loosen the two captive T5 Torx screws securing the RTC battery cover.
  32. Framework Desktop RTC Battery Replacement, Remove the RTC battery cover: étape 32, image 1 de 2 Framework Desktop RTC Battery Replacement, Remove the RTC battery cover: étape 32, image 2 de 2
    • Lift the RTC battery cover off the Mainboard and remove it.
  33. Framework Desktop RTC Battery Replacement, Disconnect the RTC battery: étape 33, image 1 de 2 Framework Desktop RTC Battery Replacement, Disconnect the RTC battery: étape 33, image 2 de 2
    • Grip the RTC battery connector and pull it straight out of its socket to disconnect it.
  34. Framework Desktop RTC Battery Replacement, Remove the RTC battery: étape 34, image 1 de 3 Framework Desktop RTC Battery Replacement, Remove the RTC battery: étape 34, image 2 de 3 Framework Desktop RTC Battery Replacement, Remove the RTC battery: étape 34, image 3 de 3
    • The RTC battery is lightly adhered to the Mainboard.
    • Use your fingers to peel the RTC battery off the Mainboard and remove it.
  35. Framework Desktop RTC Battery Replacement, Disassembly complete: étape 35, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  36. Framework Desktop RTC Battery Replacement, Connect the RTC battery: étape 36, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the RTC battery: étape 36, image 2 de 2
    • Insert the RTC battery connector into its socket and push on the edges until it's fully seated.
  37. Framework Desktop RTC Battery Replacement, Expose the adhesive: étape 37, image 1 de 3 Framework Desktop RTC Battery Replacement, Expose the adhesive: étape 37, image 2 de 3 Framework Desktop RTC Battery Replacement, Expose the adhesive: étape 37, image 3 de 3
    • Peel the white liner off the back of the RTC battery to expose the adhesive.
  38. Framework Desktop RTC Battery Replacement, Secure the RTC battery: étape 38, image 1 de 3 Framework Desktop RTC Battery Replacement, Secure the RTC battery: étape 38, image 2 de 3 Framework Desktop RTC Battery Replacement, Secure the RTC battery: étape 38, image 3 de 3
    • Orient the RTC battery so it's aligned with the white circular marking on the Mainboard.
    • Press the RTC battery onto the Mainboard to secure the adhesive.
  39. Framework Desktop RTC Battery Replacement, Place the RTC battery cover: étape 39, image 1 de 2 Framework Desktop RTC Battery Replacement, Place the RTC battery cover: étape 39, image 2 de 2
    • Place the cover over the RTC battery and align its screws.
  40. Framework Desktop RTC Battery Replacement, Install the RTC battery cover screws: étape 40, image 1 de 2 Framework Desktop RTC Battery Replacement, Install the RTC battery cover screws: étape 40, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the two captive T5 Torx screws securing the RTC battery cover.
  41. Framework Desktop RTC Battery Replacement, Place the Mainboard: étape 41, image 1 de 3 Framework Desktop RTC Battery Replacement, Place the Mainboard: étape 41, image 2 de 3 Framework Desktop RTC Battery Replacement, Place the Mainboard: étape 41, image 3 de 3
    • Grab the Mainboard by its heatsink and slide it into the chassis.
    • Align the rear ports with its cutout and the screw posts with the screw holes on the Mainboard.
    • You'll feel the Mainboard rest onto the screw posts when it's aligned properly.
    • Make sure no cables are trapped underneath the Mainboard before continuing.
  42. Framework Desktop RTC Battery Replacement, Install the Mainboard screws: étape 42, image 1 de 2 Framework Desktop RTC Battery Replacement, Install the Mainboard screws: étape 42, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the four 8.2 mm‑long Phillips screws securing the Mainboard.
  43. Framework Desktop RTC Battery Replacement, Connect the power button: étape 43, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the power button: étape 43, image 2 de 2
    • Slide the power button cable over the nine-pronged connector on the Mainboard.
  44. Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 44, image 1 de 3 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 44, image 2 de 3 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 44, image 3 de 3
    • Rotate the Desktop onto its left side so the underside of the Mainboard is facing upward.
  45. Framework Desktop RTC Battery Replacement, Install the Wi-Fi module: étape 45, image 1 de 2 Framework Desktop RTC Battery Replacement, Install the Wi-Fi module: étape 45, image 2 de 2
    • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
  46. Framework Desktop RTC Battery Replacement, Install the Wi-Fi module screw: étape 46, image 1 de 2 Framework Desktop RTC Battery Replacement, Install the Wi-Fi module screw: étape 46, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  47. Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 47, image 1 de 2 Framework Desktop RTC Battery Replacement, Reposition the Desktop: étape 47, image 2 de 2
    • Rotate the Desktop so it sits upright on your work surface.
  48. Framework Desktop RTC Battery Replacement, Place the top plate: étape 48, image 1 de 2 Framework Desktop RTC Battery Replacement, Place the top plate: étape 48, image 2 de 2
    • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
  49. Framework Desktop RTC Battery Replacement: étape 49, image 1 de 2 Framework Desktop RTC Battery Replacement: étape 49, image 2 de 2
    • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
  50. Framework Desktop RTC Battery Replacement, Install the top plate screws: étape 50, image 1 de 3 Framework Desktop RTC Battery Replacement, Install the top plate screws: étape 50, image 2 de 3 Framework Desktop RTC Battery Replacement, Install the top plate screws: étape 50, image 3 de 3
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
  51. Framework Desktop RTC Battery Replacement, Install the Right Panel: étape 51, image 1 de 3 Framework Desktop RTC Battery Replacement, Install the Right Panel: étape 51, image 2 de 3 Framework Desktop RTC Battery Replacement, Install the Right Panel: étape 51, image 3 de 3
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Right Panel and the silver base.
    • Push the Right Panel towards the base of the computer to engage the clips.
  52. Framework Desktop RTC Battery Replacement, Reposition the Mainboard: étape 52, image 1 de 2 Framework Desktop RTC Battery Replacement, Reposition the Mainboard: étape 52, image 2 de 2
    • Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
  53. Framework Desktop RTC Battery Replacement, Connect the bottom Expansion Card cable: étape 53, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the bottom Expansion Card cable: étape 53, image 2 de 2
    • Slide the bottom Expansion Card cable into its socket on the Mainboard.
  54. Framework Desktop RTC Battery Replacement, Connect the CPU power cable: étape 54, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the CPU power cable: étape 54, image 2 de 2
    • Orient the CPU power supply cable so its clip is facing the heatsink.
    • Slide the cable into its socket on the Mainboard until you feel it click into place.
  55. Framework Desktop RTC Battery Replacement, Connect the main power cable: étape 55, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the main power cable: étape 55, image 2 de 2
    • Orient the main power supply cable so its clip is facing away from the heatsink.
  56. Framework Desktop RTC Battery Replacement, Connect the top Expansion Card cable: étape 56, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the top Expansion Card cable: étape 56, image 2 de 2
    • Slide the top Expansion Card cable into its socket on the Mainboard.
  57. Framework Desktop RTC Battery Replacement, Insert the fan: étape 57, image 1 de 3 Framework Desktop RTC Battery Replacement, Insert the fan: étape 57, image 2 de 3 Framework Desktop RTC Battery Replacement, Insert the fan: étape 57, image 3 de 3
    • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
    • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
    • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
  58. Framework Desktop RTC Battery Replacement: étape 58, image 1 de 3 Framework Desktop RTC Battery Replacement: étape 58, image 2 de 3 Framework Desktop RTC Battery Replacement: étape 58, image 3 de 3
    • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
    • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
  59. Framework Desktop RTC Battery Replacement, Insert the fan duct: étape 59, image 1 de 2 Framework Desktop RTC Battery Replacement, Insert the fan duct: étape 59, image 2 de 2
    • Lay the fan duct on top of the fan with the lip facing upward.
    • Align the screw holes on the fan duct with the ones on the fan.
  60. Framework Desktop RTC Battery Replacement, Install the fan screws: étape 60, image 1 de 2 Framework Desktop RTC Battery Replacement, Install the fan screws: étape 60, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long screws securing the fan and fan duct.
  61. Framework Desktop RTC Battery Replacement, Connect the fan: étape 61, image 1 de 2 Framework Desktop RTC Battery Replacement, Connect the fan: étape 61, image 2 de 2
    • Orient the main fan cable so its two vertical lines are facing you.
    • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
  62. Framework Desktop RTC Battery Replacement, Connect the RGB cable: étape 62, image 1 de 3 Framework Desktop RTC Battery Replacement, Connect the RGB cable: étape 62, image 2 de 3 Framework Desktop RTC Battery Replacement, Connect the RGB cable: étape 62, image 3 de 3
    • Orient the RGB cable so the arrow is on the right side of the connector.
    • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
  63. Framework Desktop RTC Battery Replacement, Install the Left Panel: étape 63, image 1 de 3 Framework Desktop RTC Battery Replacement, Install the Left Panel: étape 63, image 2 de 3 Framework Desktop RTC Battery Replacement, Install the Left Panel: étape 63, image 3 de 3
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  64. Framework Desktop RTC Battery Replacement, Install the Top Panel: étape 64, image 1 de 3 Framework Desktop RTC Battery Replacement, Install the Top Panel: étape 64, image 2 de 3 Framework Desktop RTC Battery Replacement, Install the Top Panel: étape 64, image 3 de 3
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  65. Framework Desktop RTC Battery Replacement: étape 65, image 1 de 2 Framework Desktop RTC Battery Replacement: étape 65, image 2 de 2
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  66. Framework Desktop RTC Battery Replacement, Install the Handle: étape 66, image 1 de 2 Framework Desktop RTC Battery Replacement, Install the Handle: étape 66, image 2 de 2
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  67. Framework Desktop RTC Battery Replacement, Install the top panel screws: étape 67, image 1 de 3 Framework Desktop RTC Battery Replacement, Install the top panel screws: étape 67, image 2 de 3 Framework Desktop RTC Battery Replacement, Install the top panel screws: étape 67, image 3 de 3
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  68. Framework Desktop RTC Battery Replacement: étape 68, image 1 de 3 Framework Desktop RTC Battery Replacement: étape 68, image 2 de 3 Framework Desktop RTC Battery Replacement: étape 68, image 3 de 3
    • Repeat the same procedure for the other top panel screw.
  69. Framework Desktop RTC Battery Replacement: étape 69, image 1 de 3 Framework Desktop RTC Battery Replacement: étape 69, image 2 de 3 Framework Desktop RTC Battery Replacement: étape 69, image 3 de 3
    • Use your finger to close the two D-rings on the top panel screws.
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
213 014 Réputation
1 040 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 524
