Introduction
Here are the tools you will need in order to assemble, disassemble, and fix your Free Wheelchair Mission GEN 1 wheelchair.
  1. The 10mm wrench that comes attached to the footrest of the GEN 1 wheelchair fits the majority of nuts and bolts that hold together the GEN 1 wheelchair
    • The 10mm wrench that comes attached to the footrest of the GEN 1 wheelchair fits the majority of nuts and bolts that hold together the GEN 1 wheelchair
  2. The multi-purpose tool comes with the GEN 1 wheelchair and fits all nuts and bolts ranging from the 19mm bolt holding the rear wheels to the 10mm bolts that hold the wheelchair together
    • The multi-purpose tool comes with the GEN 1 wheelchair and fits all nuts and bolts ranging from the 19mm bolt holding the rear wheels to the 10mm bolts that hold the wheelchair together
    • This socket fits the 19mm bolt
    • This socket fits the 10mm bolt
    • This 10mm T-Wrench will fit all 10mm nuts and bolts that hold together the GEN 1 wheelchair
    • The tire pump may be used to inflate the rear wheels
    • The pliers are best for holding nuts in place while assembling and disassembling all bolts
    • The pliers are not included with the GEN 1 wheelchair
    • This wrench will fit the 19mm nuts and bolts holding the rear wheels to the wheelchair and the 19mm nuts and bolts holding the castor wheels to their posts
    • This tool does not come with the GEN 1 wheelchair but may be used in place of the Free Wheelchair Mission Multi-Purpose tool for the assembly and disassembly of the rear wheels and castor wheels
    • This wrench may be used for the assembly and disassembly of all 10mm nuts and bolts holding together the GEN 1 wheelchair
    • This tool does not come with the GEN 1 wheelchair but may be used in place of the T-Wrench or Free Wheelchair Mission 10mm wrench
    • These tools are used for the removal of the tire from the bicycle wheel in order to get to the inner bicycle tube
2 autre(s) ont terminé cette réparation.
Mike Sevilla
Membre depuis le 05/04/2013
180 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-7, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 9
Total : 1,083
