Aller au contenu principal
Frigidaire FFET1222QS Light Bulb Replacement
Ce dont vous avez besoin
  1. Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: étape 1, image 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: étape 1, image 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: étape 1, image 3 de 3
    • Make sure to unplug the fridge from the wall socket before proceeding.
  2. Frigidaire FFET1222QS Light Bulb Replacement: étape 2, image 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 2, image 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 2, image 3 de 3
    • Using two hands, remove the plastic latch that's covering the dead light bulb.
    • To remove the latch, place both of your thumbs on the front face of the latch. Then, with your thumbs slowly push/squeeze the face of the latch, until the latch comes off.
  3. Frigidaire FFET1222QS Light Bulb Replacement: étape 3, image 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 3, image 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 3, image 3 de 3
    • Slowly unscrew the dead bulb in the counterclockwise direction to remove it from the socket.
  4. Frigidaire FFET1222QS Light Bulb Replacement: étape 4, image 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 4, image 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 4, image 3 de 3
    • Get the new light bulb and screw it into the empty bulb socket clockwise.
  5. Frigidaire FFET1222QS Light Bulb Replacement: étape 5, image 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 5, image 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: étape 5, image 3 de 3
    • Plug the fridge back into the wall socket, then check if the light bulb is working.
  6. Frigidaire FFET1222QS Light Bulb Replacement: étape 6, image 1 de 2 Frigidaire FFET1222QS Light Bulb Replacement: étape 6, image 2 de 2
    • If the light bulb works, return the latch to its original position using your two hands.
    • When returning the latch make sure the latch’s front face is in the right direction.
    • Then slowly connect the latch to cover the new bulb and makes sure it is secured before closing the fridge door.
Daniel kenneth
Membre depuis le 09/12/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-10, O'Regan Fall 2021 Membre de l'équipe York University, Team 1-10, O'Regan Fall 2021
YORK-O'REGAN-F21S1G10
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 27
30 derniers jours : 105
Total : 2,357
