Aller au contenu principal
Frigidaire Gallery Water Filter Replacement
Ce dont vous avez besoin
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: étape 1, image 1 de 1
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: étape 2, image 1 de 2 Frigidaire Gallery Water Filter Replacement: étape 2, image 2 de 2
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: étape 3, image 1 de 3 Frigidaire Gallery Water Filter Replacement: étape 3, image 2 de 3 Frigidaire Gallery Water Filter Replacement: étape 3, image 3 de 3
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: étape 4, image 1 de 1
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Ligne d'arrivée
Tessa Etzioni
Membre depuis le 01/28/22
116 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 215
Total : 5,028
