Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
The Fugoo Style has a fabric case that can removed for cleaning, replacement, or to begin accessing the interior of the speaker.
  1. Using your hand, unscrew the large screws underneath the speaker. Using your hand, unscrew the large screws underneath the speaker.
    • Using your hand, unscrew the large screws underneath the speaker.
  2. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  3. Using your hand, gently lift the large plastic tab secured to the rubber holding (the holding is within the orange square). While lifting the tab, push the speaker out of the case. Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case. Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
    • Using your hand, gently lift the large plastic tab secured to the rubber holding (the holding is within the orange square). While lifting the tab, push the speaker out of the case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
  4. Slide the speaker completely out of the fabric casing. Slide the speaker completely out of the fabric casing.
    • Slide the speaker completely out of the fabric casing.
James Gifford
Membre depuis le 25/09/2017
546 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G4, Cannon Fall 2017 Membre de l'équipe USF Tampa, Team S3-G4, Cannon Fall 2017
USFT-CANNON-F17S3G4
4 membres
5 tutoriels rédigés
Hola
me interesa una carcasa en color rojo para el fugoo style xl, seria posible hacerla para mi?
A demás me urge arreglar otro fugoo style xl, tiene problemas para que se sostenga después de encender.
Nefer Ibrajhim - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 13
Total : 426
