Aller au contenu principal
Fugoo Style XL Midwoofer Replacement
Ce dont vous avez besoin
  1. Fugoo Style XL Midwoofer Replacement, Fabric Case: étape 1, image 1 de 2 Fugoo Style XL Midwoofer Replacement, Fabric Case: étape 1, image 2 de 2
    • Using your hand, unscrew the large screws underneath the speaker.
  2. Fugoo Style XL Midwoofer Replacement: étape 2, image 1 de 3 Fugoo Style XL Midwoofer Replacement: étape 2, image 2 de 3 Fugoo Style XL Midwoofer Replacement: étape 2, image 3 de 3
    • Using your hand, gently lift the large plastic tab secured to the rubber holding.
    • After lifting the tab, slide the speaker out of its case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
  3. Fugoo Style XL Midwoofer Replacement, Midwoofer: étape 3, image 1 de 2 Fugoo Style XL Midwoofer Replacement, Midwoofer: étape 3, image 2 de 2
    • There are 8 screws (4 on each side) holding covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
  4. Fugoo Style XL Midwoofer Replacement: étape 4, image 1 de 2 Fugoo Style XL Midwoofer Replacement: étape 4, image 2 de 2
    • Using your hand, pull the covers away from the speaker.
  5. Fugoo Style XL Midwoofer Replacement: étape 5, image 1 de 2 Fugoo Style XL Midwoofer Replacement: étape 5, image 2 de 2
    • Using a #2.0 Hex screwdriver to unscrew the 8 12mm screws depicted.
  6. Fugoo Style XL Midwoofer Replacement: étape 6, image 1 de 2 Fugoo Style XL Midwoofer Replacement: étape 6, image 2 de 2
    • Gently pull apart the front casing from the back casing.
    • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
  7. Fugoo Style XL Midwoofer Replacement: étape 7, image 1 de 2 Fugoo Style XL Midwoofer Replacement: étape 7, image 2 de 2
    • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
    • When the red bundled cable connectors are disconnected, set the outer casing aside.
  8. Fugoo Style XL Midwoofer Replacement: étape 8, image 1 de 2 Fugoo Style XL Midwoofer Replacement: étape 8, image 2 de 2
    • Carefully untangle and remove the white bundled cable connectors from the motherboard.
  9. Fugoo Style XL Midwoofer Replacement: étape 9, image 1 de 2 Fugoo Style XL Midwoofer Replacement: étape 9, image 2 de 2
    • Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
    • Using your hand, carefully remove the midwoofers.
James Gifford
Membre depuis le 09/25/17
573 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G4, Cannon Fall 2017 Membre de l'équipe USF Tampa, Team S3-G4, Cannon Fall 2017
USFT-CANNON-F17S3G4
4 membres
5 tutoriels rédigés
Un commentaire
can anyone tell me where I can buy the replacement speaker
Michael Johnsson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 398
