Aller au contenu principal
Fugoo Tough XL Bass Speaker Replacement
Ce dont vous avez besoin
  1. Fugoo Tough XL Bass Speaker Replacement, Case: étape 1, image 1 de 1
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Bass Speaker Replacement: étape 2, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement: étape 2, image 2 de 2
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Bass Speaker Replacement: étape 3, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement: étape 3, image 2 de 2
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Bass Speaker Replacement: étape 4, image 1 de 3 Fugoo Tough XL Bass Speaker Replacement: étape 4, image 2 de 3 Fugoo Tough XL Bass Speaker Replacement: étape 4, image 3 de 3
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Bass Speaker Replacement: étape 5, image 1 de 1
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Bass Speaker Replacement, Motherboard: étape 6, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement, Motherboard: étape 6, image 2 de 2
    • Carefully untangle the wires that connect the speaker to the motherboard.
  7. Fugoo Tough XL Bass Speaker Replacement: étape 7, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the two ribbon wires on the left and right side of motherboard.
    • Do not pull the cables by the cord, as this could damage the cables and the motherboard. It is best to always disconnect the cables from the base, which is closest to the motherboard, using an iFixit opening tool.
  8. Fugoo Tough XL Bass Speaker Replacement: étape 8, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement: étape 8, image 2 de 2
    • There is a hidden ribbon on the motherboard, that becomes visible once the motherboard has been pulled out.
    • Pull the motherboard halfway out.
    • Gently unplug the ribbon using tweezers.
  9. Fugoo Tough XL Bass Speaker Replacement: étape 9, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement: étape 9, image 2 de 2
    • Remove the motherboard and battery.
    • Remove the four 3 mm screws from the motherboard using a 3 mm Hex screwdriver.
  10. Fugoo Tough XL Bass Speaker Replacement, Bass Speaker: étape 10, image 1 de 1
    • Remove four 3 mm screws using a 3 mm Hex screwdriver.
  11. Fugoo Tough XL Bass Speaker Replacement: étape 11, image 1 de 2 Fugoo Tough XL Bass Speaker Replacement: étape 11, image 2 de 2
    • Pull the bass speaker from the internal case.
Austin Coats
Membre depuis le 02/17/17
107 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S19-G1, Hoffman Spring 2017 Membre de l'équipe USF Tampa, Team S19-G1, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G1
4 membres
5 tutoriels rédigés
Un commentaire
Hello, what is the power of this loudspeaker for resistances Ω, and RMS
Marcin Kopera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 787
