Aller au contenu principal
Fugoo Tough XL Speaker Replacement
Ce dont vous avez besoin
  1. Fugoo Tough XL Speaker Replacement, Case: étape 1, image 1 de 1
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Speaker Replacement: étape 2, image 1 de 2 Fugoo Tough XL Speaker Replacement: étape 2, image 2 de 2
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Speaker Replacement: étape 3, image 1 de 2 Fugoo Tough XL Speaker Replacement: étape 3, image 2 de 2
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Speaker Replacement: étape 4, image 1 de 3 Fugoo Tough XL Speaker Replacement: étape 4, image 2 de 3 Fugoo Tough XL Speaker Replacement: étape 4, image 3 de 3
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Speaker Replacement: étape 5, image 1 de 1
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Speaker Replacement, Speaker: étape 6, image 1 de 2 Fugoo Tough XL Speaker Replacement, Speaker: étape 6, image 2 de 2
    • Carefully untangle the wires that are connected from the speaker to the motherboard.
    • Using a tweezer, pull downwards on the base of each red speaker connector to remove them from the motherboard.
  7. Fugoo Tough XL Speaker Replacement: étape 7, image 1 de 3 Fugoo Tough XL Speaker Replacement: étape 7, image 2 de 3 Fugoo Tough XL Speaker Replacement: étape 7, image 3 de 3
    • Use a #3 Hex screwdriver to unscrew all six 3mm screws."
    • While holding the case with one hand, pull up on the speaker you wish to replace.
Abdul
Membre depuis le 02/17/17
527 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S19-G1, Hoffman Spring 2017 Membre de l'équipe USF Tampa, Team S19-G1, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 1,012
