Aller au contenu principal
Introduction
Remove and replace LCD screen.
Pièces
Aucune pièce spécifiée.
  1. FujiFilm FinePix A340 LCD Screen Replacement, Disassembling FujiFilm FinePix A340 Outer Case: étape 1, image 1 de 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps. To remove the battery click the area shown in the picture and the battery should loosen and pop out. Be sure it is fully removed before continuing.
  2. FujiFilm FinePix A340 LCD Screen Replacement: étape 2, image 1 de 3 FujiFilm FinePix A340 LCD Screen Replacement: étape 2, image 2 de 3 FujiFilm FinePix A340 LCD Screen Replacement: étape 2, image 3 de 3
    • First, locate all five screws on the camera. Make sure you are using the Tri-Point Y0 screwdriver. Then proceed to carefully remove all the screws. Put them in a safe place after so you don't lose them. Make sure all screws are fully removed before continuing.
  3. FujiFilm FinePix A340 LCD Screen Replacement: étape 3, image 1 de 1
    • Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • It is highly recommended to use the Tri-point Y0 screwdriver. But if your screwdriver does not fit, or you do not have the proper one, you can use a hot glue gun to fix the screwdriver to the head of the screw. Wait for it to harden slightly, and then try to remove the screws. Be very careful so you don't damage the screws.
  4. FujiFilm FinePix A340 LCD Screen Replacement: étape 4, image 1 de 2 FujiFilm FinePix A340 LCD Screen Replacement: étape 4, image 2 de 2
    • After making sure all the screws are out it is time to remove the outer case. Grab the case as shown in the first picture and pull back the outer casing. Use caution and pull the casing back slowly.
  5. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: étape 5, image 1 de 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  6. FujiFilm FinePix A340 LCD Screen Replacement: étape 6, image 1 de 1
    • Carefully pull the LCD screen away from the board it is connected to.
  7. FujiFilm FinePix A340 LCD Screen Replacement: étape 7, image 1 de 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  8. FujiFilm FinePix A340 LCD Screen Replacement: étape 8, image 1 de 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  9. FujiFilm FinePix A340 LCD Screen Replacement: étape 9, image 1 de 1
    • Now that everything has been disconnected from the board, remove LCD screen.
Cody
Membre depuis le 18/04/2010
47 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 7-11, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 6
Total : 5,985
