Aller au contenu principal
FujiFilm FinePix A340 LCD Screen Replacement
Ce dont vous avez besoin
  1. FujiFilm FinePix A340 LCD Screen Replacement, Outer Case: étape 1, image 1 de 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 LCD Screen Replacement: étape 2, image 1 de 3 FujiFilm FinePix A340 LCD Screen Replacement: étape 2, image 2 de 3 FujiFilm FinePix A340 LCD Screen Replacement: étape 2, image 3 de 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 LCD Screen Replacement: étape 3, image 1 de 2 FujiFilm FinePix A340 LCD Screen Replacement: étape 3, image 2 de 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: étape 4, image 1 de 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 LCD Screen Replacement: étape 5, image 1 de 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 LCD Screen Replacement: étape 6, image 1 de 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 LCD Screen Replacement: étape 7, image 1 de 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 LCD Screen Replacement: étape 8, image 1 de 1
    • Now that everything has been disconnected from the board, remove LCD screen.
Cody
Membre depuis le 04/18/10
47 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 7-11, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 6,089
