Introduction
The replacement guide will show you how to access the battery door on a Fujifilm FinePix S5100 camera. In order to access the door, you will need to disconnect circuit board connections. These connections are very fragile so handle these components with care. If you follow these steps and are careful while taking apart the camera, everything will go smoothly and quickly. It is also recommended to use a magnetic pad to place the screws on in conjunction with the magnetic tools mentioned above. This is to prevent or minimize the chances of losing or misplacing a screw.
Ce dont vous avez besoin
Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
Turn the camera so the screen is facing you and the camera lens is facing away from you.
Remove the single 1.3mm Phillips #000 screw.
Carefully remove the battery compartment from the rest of the camera.
2 autres ont terminé cette réparation.
