Introduction
This guide is meant to be used with the intention to replace the Fujifilm FinePix HS30EXR motherboard, which is the central part of the camera.
Warning: As the motherboard plays such a central role in the camera's function, the many wires and cables that connect the many parts to the camera together can be damaged in the replacement process. To avoid any excess damage, treat all wires and cables with care.
Ce dont vous avez besoin
Flip the camera so that the bottom is facing upwards.
With the Phillips #00 screwdriver, remove all four screws.
Slowly and carefully pull the frame away to have a better view of the inside.
2 commentaires
have you instructions to remove power on and selector assembly?
have you istructions to remove the poweron switch asm. for the hs30exr?
