Introduction
This guides serves to help the user replace the LCD Screen.
Warning: The replacement of the screen requires great care, as any force could damage the frame or any internal cables/wires that may be essential to the camera's function. To avoid damage, treat the frame with care when prying it off, and treat and wires or cables with care as well.
Ce dont vous avez besoin
Flip the camera so that the bottom is facing upwards.
With the Phillips #00 screwdriver, remove all four screws.
Slowly and carefully pull the frame away to have a better view of the inside.
Peel back (or off) the black tape to expose more of the inside of the camera.
Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
4 autres ont terminé cette réparation.
Un commentaire
Ecran de rechange trouvé chez elecok.
Tuto testé, fonctionne aussi pour le Fuji HS20 EXR.
Bravo et Merci à Andrew et aux contributeurs
