Introduction
In this guide, we will give you step-by-step instructions on how to replace the battery compartment door of the Fujifilm FinePix S4800. This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera.
Ce dont vous avez besoin
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Once the rear case is removed, gently separate the battery compartment door from its position.
