Introduction
Water may get trapped within the casing of the camera, and to prevent further damage, removing the panels allows for cleaning the camera inside and out. These panels can also be replaced if they are cracked, which allows water to seep in.
Ce dont vous avez besoin
Remove one Phillips screw with a Phillips head 0 screwdriver
Remove one hex head screw with a hex 1.3 screwdriver bit.
Un commentaire
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
