Aller au contenu principal
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: étape 2, image 1 de 1
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: étape 3, image 1 de 2 Fujifilm FinePix Z1 Battery Replacement: étape 3, image 2 de 2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: étape 4, image 1 de 1
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: étape 5, image 1 de 1
    • Remove the battery and replace with a new one.
Carra
Membre depuis le 01/30/18
533 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S2-G4, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 677
