Aller au contenu principal
Fujifilm FinePix Z1 LCD Screen Replacement
Ce dont vous avez besoin
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: étape 2, image 1 de 3 Fujifilm FinePix Z1 LCD Screen Replacement: étape 2, image 2 de 3 Fujifilm FinePix Z1 LCD Screen Replacement: étape 2, image 3 de 3
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: étape 3, image 1 de 2 Fujifilm FinePix Z1 LCD Screen Replacement: étape 3, image 2 de 2
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: étape 4, image 1 de 3 Fujifilm FinePix Z1 LCD Screen Replacement: étape 4, image 2 de 3 Fujifilm FinePix Z1 LCD Screen Replacement: étape 4, image 3 de 3
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
Carra
Membre depuis le 01/30/18
533 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S2-G4, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 286
