Aller au contenu principal
Fujifilm X-M1 Disassembly
Ce dont vous avez besoin
  1. Fujifilm X-M1 Disassembly, Fujifilm X-M1 Disassembly: étape 1, image 1 de 1
    • If you haven't done so already, remove the lens from the camera.
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  2. Fujifilm X-M1 Disassembly: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  3. Fujifilm X-M1 Disassembly: étape 3, image 1 de 1
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  4. Fujifilm X-M1 Disassembly: étape 4, image 1 de 3 Fujifilm X-M1 Disassembly: étape 4, image 2 de 3 Fujifilm X-M1 Disassembly: étape 4, image 3 de 3
    • Remove the six 6.5 mm Phillips screws from the lens mount.
    • Use tweezers to remove the top metal ring and the thin metal ring below it .
  5. Fujifilm X-M1 Disassembly: étape 5, image 1 de 1
    • Remove the four 4.3 mm screws securing the sensor to the front case.
  6. Fujifilm X-M1 Disassembly: étape 6, image 1 de 2 Fujifilm X-M1 Disassembly: étape 6, image 2 de 2
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  7. Fujifilm X-M1 Disassembly: étape 7, image 1 de 3 Fujifilm X-M1 Disassembly: étape 7, image 2 de 3 Fujifilm X-M1 Disassembly: étape 7, image 3 de 3
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  8. Fujifilm X-M1 Disassembly: étape 8, image 1 de 1
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  9. Fujifilm X-M1 Disassembly: étape 9, image 1 de 2 Fujifilm X-M1 Disassembly: étape 9, image 2 de 2
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  10. Fujifilm X-M1 Disassembly: étape 10, image 1 de 3 Fujifilm X-M1 Disassembly: étape 10, image 2 de 3 Fujifilm X-M1 Disassembly: étape 10, image 3 de 3
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  11. Fujifilm X-M1 Disassembly: étape 11, image 1 de 1
    • Slide the frame around the LCD to remove it from the camera.
  12. Fujifilm X-M1 Disassembly: étape 12, image 1 de 1
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  13. Fujifilm X-M1 Disassembly: étape 13, image 1 de 2 Fujifilm X-M1 Disassembly: étape 13, image 2 de 2
    • Use tweezers to unhook the speaker near the left handgrip.
  14. Fujifilm X-M1 Disassembly: étape 14, image 1 de 2 Fujifilm X-M1 Disassembly: étape 14, image 2 de 2
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  15. Fujifilm X-M1 Disassembly: étape 15, image 1 de 3 Fujifilm X-M1 Disassembly: étape 15, image 2 de 3 Fujifilm X-M1 Disassembly: étape 15, image 3 de 3
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
  16. Fujifilm X-M1 Disassembly: étape 16, image 1 de 1
    • Use tweezers to remove the three pieces of tape covering the components of the motherboard.
  17. Fujifilm X-M1 Disassembly: étape 17, image 1 de 3 Fujifilm X-M1 Disassembly: étape 17, image 2 de 3 Fujifilm X-M1 Disassembly: étape 17, image 3 de 3
    • Desolder the three pairs of red and black wires attached to the mother board.
    • Learn more about desoldering wires here.
  18. Fujifilm X-M1 Disassembly: étape 18, image 1 de 2 Fujifilm X-M1 Disassembly: étape 18, image 2 de 2
    • Use tweezers to remove the grey cushion located below the flash button.
  19. Fujifilm X-M1 Disassembly: étape 19, image 1 de 3 Fujifilm X-M1 Disassembly: étape 19, image 2 de 3 Fujifilm X-M1 Disassembly: étape 19, image 3 de 3
    • Use two fingers to remove the two ribbon cables in the bottom left corner of the motherboard.
  20. Fujifilm X-M1 Disassembly: étape 20, image 1 de 3 Fujifilm X-M1 Disassembly: étape 20, image 2 de 3 Fujifilm X-M1 Disassembly: étape 20, image 3 de 3
    • Use the flat end of a spudger to unlock the four indicated ZIF connectors.
    • Use two fingers to pull the ribbon cables out of the connectors.
  21. Fujifilm X-M1 Disassembly: étape 21, image 1 de 2 Fujifilm X-M1 Disassembly: étape 21, image 2 de 2
    • Remove the 3.3 mm Phillips screw from the upper left corner of the motherboard.
    • Remove the 2.4 mm Phillips screw in the bottom right corner of the motherboard.
    • Use two fingers to remove the motherboard from the front case.
  22. Fujifilm X-M1 Disassembly: étape 22, image 1 de 3 Fujifilm X-M1 Disassembly: étape 22, image 2 de 3 Fujifilm X-M1 Disassembly: étape 22, image 3 de 3
    • Use tweezers to remove the black plastic tape at the top of the battery compartment.
    • Insert a Phillips #00 screwdriver through the hole beneath the black tape to remove a 4.8 mm screw.
    • Insert a Phillips #00 screwdriver through the white tamper evident sticker to remove a second 4.8 mm screw.
  23. Fujifilm X-M1 Disassembly: étape 23, image 1 de 1
    • Remove the 3.7 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 4.2 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 6.2 mm Phillips screw hiding between the sensor mount and the battery compartment.
  24. Fujifilm X-M1 Disassembly: étape 24, image 1 de 2 Fujifilm X-M1 Disassembly: étape 24, image 2 de 2
    • Press the flash button to release the flash assembly.
    • Remove the 3.4 mm Phillips screw in the back of the flash compartment.
  25. Fujifilm X-M1 Disassembly: étape 25, image 1 de 2 Fujifilm X-M1 Disassembly: étape 25, image 2 de 2
    • Remove the top plate.
  26. Fujifilm X-M1 Disassembly: étape 26, image 1 de 1
    • Remove the sensor assembly.
  27. Fujifilm X-M1 Disassembly: étape 27, image 1 de 2 Fujifilm X-M1 Disassembly: étape 27, image 2 de 2
    • Remove the battery compartment.
  28. Fujifilm X-M1 Disassembly: étape 28, image 1 de 2 Fujifilm X-M1 Disassembly: étape 28, image 2 de 2
    • Remove the four 2.6 mm Phillips screws from the LCD hinges.
    • Tilt the LCD away from the metal frame.
    • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
  29. Fujifilm X-M1 Disassembly: étape 29, image 1 de 2 Fujifilm X-M1 Disassembly: étape 29, image 2 de 2
    • Use two fingers to pull the ribbon through the hole in the metal frame.
    • Remove the LCD from the metal frame.
  30. Fujifilm X-M1 Disassembly: étape 30, image 1 de 2 Fujifilm X-M1 Disassembly: étape 30, image 2 de 2
    • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
  31. Fujifilm X-M1 Disassembly: étape 31, image 1 de 2 Fujifilm X-M1 Disassembly: étape 31, image 2 de 2
    • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
    • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
  32. Fujifilm X-M1 Disassembly: étape 32, image 1 de 3 Fujifilm X-M1 Disassembly: étape 32, image 2 de 3 Fujifilm X-M1 Disassembly: étape 32, image 3 de 3
    • Use a plastic opening tool to pry the LCD case open.
    • Once the case is open, pull the ribbon through the hole on the back case.
  33. Fujifilm X-M1 Disassembly: étape 33, image 1 de 1
    • Remove the LCD from the screen cover.
  34. Fujifilm X-M1 Disassembly: étape 34, image 1 de 1
    • You have successfully disassembled the Fujifilm X-M1!
7 autres ont terminé cette réparation.
Kelsea Weber
Membre depuis le 11/12/15
20 009 Réputation
32 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 895 tutoriels rédigés
7 commentaires
what about the top plate??? no one apparently knows how to remove the rotary switches from the upper assembly. Still looking for someone to show how those things are assembled
Juan Paz - Réponse
Hi, I have disassembled in more detail the whole camera and collected in reverse order to every detail , I can send you my photos for a complete collection of disassembly of the camera, my email: tyapa141465@mail.ru
Felus Felus - Réponse
Great article.
I have disassembled mine in order to clean dust inside sensor assembly, i took apart #26 using top 2 screws and the bottom one.
Unfortuntatly in the middle there were spacers, on the bottom 3 of them, on the upper side i have found 5 little metal spacers… without knowing how many were on the left, and on the right. Do you have pictures of this stage? Tya.
Francesco - Réponse
Большое спасибо автору статьи. Благодаря ей разобрали Fuji X-A2 для ремонта (после падения камеры не работала часть функций). После разборки и последующей сборки камера работает как новая. Только черную пленку под LCD пришлось выбросить, потому что она одноразовая
Lena Raigorodskiy - Réponse
Many thanks to the author of the article. Thanks to her dismantled Fuji X-A2 for repair (after the fall of the camera did not work part of the functions). After disassembly and subsequent Assembly, the camera works as new. Only the black film under the LCD had to be thrown away, because it is disposable
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 119
Total : 11,969
