Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide provides instructions for removing and replacing the speakers on your Fujitsu LIFEBOOK P7010D.
  1. Place the laptop upside down on a table.
    • Place the laptop upside down on a table.
  2. Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. While holding the tabs down, slowly pivot the battery up.
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0. Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
  5. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  6. Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer. Raise the monitor as you normally would until it pops out by itself.  Rotate the left side up and to the right to unhook hinges that may catch on the computer. Lay the monitor flat next to the computer.
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
  7. Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons. Lift the case out and set it aside.
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
  8. Using the same spudger, pry the top of the keyboard up above the "F2" key. Turn the computer so that the bottom is facing you. The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
  9. Disconnect the keyboard by gently pulling on the hard plastic square straight up from  the white connector. Disconnect the keyboard by gently pulling on the hard plastic square straight up from  the white connector.
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
  10. Remove four 2.4mm screws using the Phillips #0 screwdriver from each side of the audio speakers. Note that the speaker with the white and black wires are on the left and the red and black wires are on the right. Place the speakers to the side of the computer.
    • Remove four 2.4mm screws using the Phillips #0 screwdriver from each side of the audio speakers.
    • Note that the speaker with the white and black wires are on the left and the red and black wires are on the right.
    • Place the speakers to the side of the computer.
  11. Use your fingers or a spudger to remove the white connector from its port. Use your fingers or a spudger to remove the white connector from its port. Use your fingers or a spudger to remove the white connector from its port.
    • Use your fingers or a spudger to remove the white connector from its port.
Nicholas Ross
Membre depuis le 20/01/2012
167 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-31, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 membres
18 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 2,368
