Aller au contenu principal
Fujitsu LifeBook N3510 Display Replacement
Ce dont vous avez besoin
  1. Fujitsu LifeBook N3510 Display Replacement, Battery: étape 1, image 1 de 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Display Replacement: étape 2, image 1 de 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: étape 3, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: étape 3, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: étape 3, image 3 de 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Display Replacement: étape 4, image 1 de 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Display Replacement: étape 5, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 5, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 5, image 3 de 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Display Replacement: étape 6, image 1 de 2 Fujitsu LifeBook N3510 Display Replacement: étape 6, image 2 de 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Display Replacement: étape 7, image 1 de 2 Fujitsu LifeBook N3510 Display Replacement: étape 7, image 2 de 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Display Replacement, Keyboard: étape 8, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement, Keyboard: étape 8, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement, Keyboard: étape 8, image 3 de 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Display Replacement: étape 9, image 1 de 2 Fujitsu LifeBook N3510 Display Replacement: étape 9, image 2 de 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Display Replacement: étape 10, image 1 de 2 Fujitsu LifeBook N3510 Display Replacement: étape 10, image 2 de 2
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Display Replacement, Metal Motherboard Cover: étape 11, image 1 de 1
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Display Replacement: étape 12, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 12, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 12, image 3 de 3
    • Lift the cover with fingers and remove.
  13. Fujitsu LifeBook N3510 Display Replacement, Display: étape 13, image 1 de 1
    • Remove labeled screws.
  14. Fujitsu LifeBook N3510 Display Replacement: étape 14, image 1 de 1
    • Remove the screws from the bottom of the hinge as shown in the image.
  15. Fujitsu LifeBook N3510 Display Replacement: étape 15, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 15, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 15, image 3 de 3
    • Use a spudger to detach and remove cables from the motherboard.
  16. Fujitsu LifeBook N3510 Display Replacement: étape 16, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 16, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 16, image 3 de 3
    • Unplug highlighted cables from the wireless module.
  17. Fujitsu LifeBook N3510 Display Replacement: étape 17, image 1 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 17, image 2 de 3 Fujitsu LifeBook N3510 Display Replacement: étape 17, image 3 de 3
    • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
2 autres ont terminé cette réparation.
Neil Daniels
Membre depuis le 01/17/11
1 411 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 5-18, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 membres
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 4,439
