Introduction
If your Lifebook won't connect to a wireless network this guide will show you how to replace a wireless adapter so your Lifebook will get a signal.
Pièces
Aucune pièce nécessaire.
To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
  • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
  • Push the two tabs in towards the laptop.
  • Lift the battery up and out from the frame of the laptop.
Ajouter un commentaire
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  • Lift the hinge cover.
  • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  • Use the tweezers to disconnect the ribbon cable from the motherboard.
  • With the tweezers detach hinge cover cables from the motherboard.
  • Remove hinge cover.
  • Lift keyboard enough to show the ribbon cable.
  • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  • Use a plastic opening tool to release the ribbon cable from the motherboard.
  • Push the secure clips outward.
  • The Adapter should pop up.
  • Use tweezers to remove the wires from the Adapter.
  • Take out the Adapter and carefully pull the wires out from the metal casing.
Jaimie Nakamura
Membre depuis le 20/03/2018
205 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G5, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G5, Peak Spring 2018
UMASSD-PEAK-S18S5G5
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 25
